Results 1 to 9 of 9
Thread: Liquid or Paste wax, which one is better?
    Dec 2004
    85
    14
    Has it been proven that paste or liquid wax, is better than the other, what is Meguiar's opinion on the two, do you give up speed and easiness, are you getting the exact ingredients (minus the water) by using one or the other, have there been a side by side comparison, is there more pop,slickness,etc,i wonder when i see both products on the shelf and would like to know,without buying both waxes, I'm talking about the gold class waxes and the NXT waxes and comparing liquid or paste form.
    Registered Member Lt1Corvette's Avatar
    Aug 2004
    643
    20
    I have always been a big fan of paste waxes. I like the ease of application and ability to setup a real even coat over the entire vehicle. However, I also like liquid waxes because of how fast they can be applied and removed. When it comes to look and durability, I find it to be roughly the same. If there is a difference, I have never noticed it. I think it just comes down to which way you like to apply it. I like hand waxing, so paste is a better setup for me.
    Dec 2004
    87
    14
    It all depends from the manufacturer. From what I know, Megs liquid waxes were no different from their paste counterparts. The only reason I guess for the liquid and paste is the fact that some detailers prefer one over the other because of usage. Liquid is good if you use the polisher to do your LSP. Paste if you apply LSP by hand.
    On the other hand, some detailers believe they get more durability from the paste than the liquid. I still say this depends on the manufacturer. Let's say the 3M Show Car Liquid Wax and 3M Show Car Paste Wax. In my own experience the paste is more durable than the liquid. The reason I guess is that "acrylic silicone flouropolymer" (A.S.F.) is present in the paste version but not in the liquid version. You will also notice the price difference of the two.
    But to my knowledge, there's nothing like this difference in the chemical composition of megs waxes in the paste and liquid version. They're the same.
    Mike or Tim would still have to confirm this...
    I wash and wash my car until the whole thing disappeared!
    perpetual noob Mosca's Avatar
    63
    713
    22
    For all practical purposs they are equal, but you get a whole lot more product with a paste. So you get ease of use with a liquid, but you pay for it.
    Liquids are paste waxes with more solvents in them. Solvents=inert product, therefore less bang per buck.
    One important advantage of liquid waxes, though, is that you are never putting a dirty pad back into the product. So with a liquid, if you do get a little speck or two of dirt on the pad, it doesn't get introduced into the can.
    Tom
    As the light changed from red to green to yellow and back to red again, I sat there thinking about life. Was it nothing more than a bunch of honking and yelling? Sometimes it seemed that way.
    Okanagan Valley, BC
    4,544
    391
    Hey,
    The only real difference between the liquid and paste versions, besides the obvious , is the manner in which they can be applied. But otherwise, their durability should be the same.
    Now with that said, sometimes, it is just nice to apply a paste wax by hand! It gives an "old school" feel!
    Tim
    Dec 2004
    85
    14
    Hey all thanks for the replys,i guess i wil stay with liquid form,for ease,etc,still wonder what Meguiars official reply might be...
    Okanagan Valley, BC
    4,544
    391
    Well then....
    "While I've used the new NXT Tech Wax in the paste version, I haven't done any side-by-side comparisons. That said, historically there is no difference between the liquid and paste versions of Meguiar's waxes and I suspect this will be true of this new paste wax. Liquids tend to be easier to apply by machine.
    The difference is primarily to cater to the preference of the user.
    Mike"
    Plus here...
    http://www.meguiarsonline.com/forums...d+versus+paste
    How's that?
    Tim
    57
    24,796
    517
    This is the common perception on the differences between a paste and a liquid wax. While this may be true for other brands, it's not the case for Meguiar's waxes.
    Tom
    That's a good point, there have been times when I have looked into my can of #16 and seen specks of dirt, which I then pick out with my fingernail. The idea is to make sure your surface is clean before applying your wax so this doesn't happen, but even if you do everything you can to work on a clean car in a clean environment, it is possible to pick up a contaminant with your wax pad and introduce it to your wax can.
    Just yesterday, at the CorvetteForum class, the question came up about when you should switch to a new, clean applicator pad. The answer it to turn your wax pad over occasionally and inspect it for contaminants such as a dirt particle, if you see any remove them or switch to a new, clean wax pad.
    Dec 2004
    85
    14
    all right ,i learn somthing every time i log on,guess i will stick with the liquids,thanks for the responses,i consider this thread closed...
  1. Liquid or Paste Wax?
    By Snowman in forum Member Polls
    Last Post: Feb 23rd, 2013, 08:02 AM
  2. NXT 2.0 tech wax- PASTE vs LIQUID?
    By Zach W. in forum Detailing 101
    Last Post: Nov 21st, 2008, 02:22 PM
  3. Liquid vs. Paste wax
    By onnfire in forum Detailing 101
    Last Post: Jun 17th, 2006, 05:58 PM
  4. NXT Paste + PC = Who needs a liquid wax?
    By gb387 in forum Meguiar's Product Raves
    Last Post: May 5th, 2006, 12:04 PM
  5. whats to do after NXT Paste/Liquid WaX?
    By rclab1 in forum Detailing 101
    Last Post: Apr 1st, 2006, 10:59 AM
