D151 Paint Reconditioning Cream Question
Results 1 to 10 of 12
Thread: D151 Paint Reconditioning Cream Question
    Aug 2005
    30
    Ok, I'm looking to pick up some D151 to speed up my daily driver details. Most people don't want to spend the money for the extra steps for a full detail. My question is what is the duration for the protection after using this? 1 2 3 months etc...
    I don't mind topping it but I'd like to use that as an up-sell. I would like to tell them it will last "this" long and tell them I could seal it and it will last "this" long....
    Formerly 101impala Andy M.'s Avatar
    May 2004
    Philadelphia, PA
    50
    3,969
    346
    Re: D151 Paint Reconditioning Cream Question
    First, let me say D151 is a really awesome product and you will love to use it and the results you achieve.
    As for your question though, there are so many factors that will effect the longevity of the product. Proper prep of coure is necessary and one of the most important steps. But you also have to factor in where the vehicle is parked, outdoors all the time or garaged, daily driver or weekend warrior. What kind of climate? Hot and sunny, more rain than not, snow, salt, etc. Also, is the owner of the vehicle properly maintaining it? Correct washing methods, washing frequently, using the correct soap? I use D151 a lot and normally top with a sealant. I would try to stay away from saying, "ok, you are good for 6 months right now" Because you can never tell.
    Hope that helps a little,
    Andy
    Andy M. Moderator
    Aug 2005
    30
    Quote Originally Posted by Andy M. View Post
    Andy
    Man you hit it on the head! I think about longevity of waxes/sealants but that's me taking care of my own cars. I do have to think more in the customers shoes though. I see the condition of the cars before I work on them and the when I'm finished. I know if I see it again, its going to look like I never touched it. That's the one part about detailing that's tough, knowing you fix it up just so it can get trashed again. Job security?
    Sep 2005
    14,242
    535
    There really is no set answer. To many variables.
    You will like using #151. Great product.
    Registered Member EssieK's Avatar
    Nov 2009
    Norway
    23
    9
    Having gone through a gallon and a half myself I have to say that generally speaking the protection left behind from D151 is not sufficient or long-lasting enough. Yes, left to haze it'll leave behind some protection, but I always top up my 1-product details with another wax-based LSP (not saying 1-step, since D151 is incredible versatile in application methods (wool, cut, polish and glaze-pads can be used)), and I absolutely love the stuff.
    09 Toyota Verso Polar Blue Metallic 1.8 MultidriveS Premium
    - paint softer than butter
    Trabuco Canyon, CA
    21,324
    1135
    Remember that D151 was specifically formulated for high volume reconditioning facilities where the main concern is fast correction and some gloss enhancement along with a bit of protection, all in a single step. It was never intended to be a product for the highly discerning detailer seeking a truly high end finish with long lasting protection. Yes, it can yield an incredible finish under the right circumstances, but at an MSRP of $35/gallon there are going to be some compromises compared to, say, the combination of M205 and NXT 2.0.
    The cut of D151 and M205 are pretty similar (when used identically - same pad, same pressure, etc) but M205 costs as much per quart as D151 does per gallon! And NXT is half that price for just 18 ounces!!
    So, keeping D151 in the proper context it's a fantastic product. Just don't expect too much more from it than what (and who) it was designed for.
    Sep 2012
    Renton
    6
    Mr.Stoops,
    Will D151 produce a result similar to Quick Detailer?
    I mean, will there be any similarities in cutting action and glosss?
    Thanks.
    Trabuco Canyon, CA
    21,324
    1135
    There is a similarity between D151 and M66 only in so much as both can be called all-in-one type products. But D151 is suitable for use with a rotary buffer and wool pad for much higher cut than M66 can give. You can also use D151 much less aggressively, like with a polishing pad on a DA. If used under identical conditions (same tool, same pad, same speed, same pressure, same paint) you'll probably still get more cut out of D151 but maybe a slightly better finish out of M66.
    Registered Member jarred767's Avatar
    Jan 2007
    Bend, OR
    34
    687
    18
    I have noticed a little of the same things Mike. However, with just recently starting to use D151 (I've always used M66 in the past and really like it), I can't attestTFT its longevity. If left under the exact same circumstances, which one of these two would last longer in protecting the paint, or are they relatively similar?
    Dynamic Detailing
    541.668.0480
    Nov 2010
    Vancouver
    1,216
    20
    I was thinking that once I get my cars to where I am 100% happy, in regards to swirls, minor defects....would using 151 or 66 once a month with a black finishing pad maintain the swirl free paint, assuming I wash correctly. I figure the protection on either 151 or 66 would last a month, I do plan on using UQW in between using 151/66
    "STRIFE" aka Phil
  1. What is the meaning of soft paint?
    Last Post: Jan 23rd, 2009, 10:23 PM
  2. What is the meaning of soft paint?
    By zerolam in forum Detailing 101
    Last Post: Jan 2nd, 2008, 07:27 AM
  3. #21 by hand ?
    By hardisk88 in forum Detailing 101
    Last Post: May 17th, 2006, 09:23 AM
  4. Claying im stuck ??
    By WhiteCamaro88 in forum Detailing 101
    Last Post: Jun 21st, 2005, 02:03 PM
