Results 1 to 10 of 14
Thread: what grit for headlights?
    Jan 2006
    152
    14
    So I used the Rain-X headlight kit on my headlights and had a nice improvement but I think I need to go through the process again. I still have all of the ingredients but I completely killed the sandpaper that comes in the kit. Does anyone know what grit to use as a replacement? I might benefit from starting with one that is slightly more coarse than came with the kit originally.
    Thanks!
    Apr 2010
    Ocala Florida
    162
    Re: what grit for headlights?
    3m makes an excellent kit for restoring headlights. As long as you have a power drill, that is probably your best route. It starts with a 500 grit sanding disc and goes up to 2000 grit. The final step is a 3000 grit sanding pad. It's very user friendly and as long as you tape off your headlights, you wont ruin anything.
    ChrisThompsonsCustom@gmail.com
    www.ChrisThompsonsCustom.webs.com
    (352) 897-0050
    Lexus Enthusiast Megafast13's Avatar
    Aug 2008
    Cincinnati, Ohio
    25
    1,706
    32
    Go to your local walmart and go to the automotive/DIY Painting section.
    Look for the 3M sandpaper. You want to get 2000Grit, 3000Grit and/or 2500Grit.
    After going through the sanding process use Meguiars M105 (or Ultimate Compound) and PlastX
    Matt
    Trabuco Canyon, CA
    21,323
    1135
    What we've done during Thursday Night Open Garage sessions is to use our new 3" sanding/finishing discs and then finish off with the wool pad from the consumer headlight kit and some PlastX. We use 1000 grit finishing disc to start, then follow with 3000 grit finishing, and then finish off with the wool pad on a drill and some PlastX.
    On extremely oxidized and damaged lenses our Professional Headlight and Spot Repair Kit offers grit as coarse as 320 (dry) for initial sanding and then progressively finer from there. It is amazing what can be done to bring truly horrible lenses back to life.
    May 2004
    1,085
    24
    I have used PlastX with little success on my headlights.
    Should I use SwirlX (or water) with 200-grit sandpapers? Using sandpaper scares me a bit, it sounds aggressive. I don't have a rotary so I will be using it by hand.
    Registered Member Fly Bye's Avatar
    Nov 2009
    Nor Cal
    51
    731
    16
    Quote Originally Posted by mis3 View Post
    200-grit sandpaper?
    200 grit is pretty coarse.
    May 2004
    1,085
    24
    You're right.
    I meant 2000 grit.
    Jul 2010
    Dallas, TX
    87
    8
    Is it possible to use your G110v2 with the S3BP backing plate and S3FIS interface and sanding discs to do a headlight restoration? Also, what speed would you use? I guess on the final step you would want to use a W8204 and Plastix?
    Trabuco Canyon, CA
    21,323
    1135
    Now that we've established you actually meant 2000 grit, let's continue with the rest of your question/concerns. You want to use water as the lube, not SwirlX or any other paint cleaner. Using sandpaper might sound aggressive, and it certainly can be if you go with a very coarse grit paper, but even 1000 grit isn't terribly aggressive - if used correctly. One thing you never want to do is use sandpaper literally "by hand". You should always have an interface pad of some sort otherwise you end up with pressure points from your fingers and very uneven sanding. It's wise to tape off the surrounding body work, and then use a sanding pad with the paper wrapped around it. Our S3HP hand pad used with our 1000 grit and 3000 grit 3" finishing discs is a great combination for correcting even very badly yellowed and oxidized headlights. The first run of 1000 grit will make the lights look very frosted and dull, which sometimes does scare people () but the 3000 grit follow up starts to bring the shine back. Removal of the 3000 grit sanding marks is then a piece of cake with some PlastX and either the wool pad from the consumer headlight restoration kit or even a W8204 4" soft buff pad with some M105.
    Quote Originally Posted by skipper1 View Post
    This is another option and it works quite well, provided the adjacent body panels allow easy access to the headlight lens assembly. You definitely want the foam interface pad there, and use the same grits as mentioned above. You should run the D/A at speed 3 to 4 - slower becomes more aggressive as the abrasive disc can more easily cut into the surface, faster becomes less aggressive since the disc will actually start to hydroplane on the water you're using as a lube. Follow up with M105 on a W8204 pad, chase that with M205 on a W9204 finishing pad and you should be good to go.
    Jul 2010
    Dallas, TX
    87
    8
    Michael, sorry but I now have more questions.
    So I should use 1000 grit starting out dry then switch to the 3000 grit and wet sand with my da on speed 3 or 4, then wrap it up with M105 on an 8204 then M205 on a 9204.
    The question is, what about Meguiar's Unigrit 1000 & 3000 finishing foam pads. Couldn't the foam pads be used several times where the sand paper is history after one use? No one ever talks about the foam sanding pads and I just wanted your thoughts. Sand paper vs the foam.
  1. Using Meguiar's New Pro Headlight & Spot Repair Kit
    By Michael Stoops in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: Nov 15th, 2011, 09:26 AM
  2. How To: PlastX Headlight Restoration (Step by w/ Pics)
    By 97 Supra in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: Jun 2nd, 2010, 10:02 AM
  3. Grit Guard Fit???? Does anyone else have this problem??
    By rgcurtis in forum The Break Room
    Last Post: Jun 5th, 2009, 03:09 PM
  4. 21-09B vs 2500 grit sanding marks by hand
    By BlueZero in forum Consumer Line - Product Reviews
    Last Post: Oct 21st, 2008, 08:09 AM
  5. Grit Guard
    By scrub in forum Meguiar's Product Raves
    Last Post: Jan 11th, 2006, 07:26 PM
