Results 1 to 5 of 5
Thread: Needing help with rubber trim around my trunk...
  1. #1
    Registered Member strader327's Avatar
    Join Date
    Apr 2010
    Location
    Corbin, Ky. USA
    Posts
    173
    Rep Power
    5
    Question Needing help with rubber trim around my trunk...
    http://meguiarsonline.com/forums/pho...0/ppuser/29734
    Should I try to glue it back with something? I've tried regluar super glue but it doesn't hold well. What could adhesive would work if anything? If there is nothing that I could use other than super glue, would it look better if I just cut the trim out of the trunk area? Thank you for your time guys!
  2. #2
    Registered Member BillyJack's Avatar
    Join Date
    Jun 2010
    Location
    Pittsburgh, PA
    Posts
    424
    Rep Power
    9
    Re: Needing help with rubber trim around my trunk...
    There is a black adhesive made just for weatherstrips. It's called 3M Weatherstrip adhesive and should be available in any parts store. You'll need to to tape the loose piece in place long enough for the glue to set up. Won't be perfect, but if repaired carefully it will look much better. It appears from your picture that the damaged area is not on the actual sealing surface of the w/strip. If so, you can attempt to neatly trim away the torn area without compromising the seal.
    Bill
  3. #3
    Reforming paint abuser RogueGypsy's Avatar
    Join Date
    Mar 2008
    Location
    The Great NorthWet
    Posts
    279
    Rep Power
    8
    +1 for what Billyjack said.
    Adding to that, weather stripping is pretty cheap. Your local parts store should have it in bulk, kits for specific vehicles and single pieces for specific vehicles. So if the piece is too damaged to seal, get another since you have to adhere it anyway.
    And a word of caution with the 3M weather strip adhesive, use in a well ventilated area, that stuff is strong and toxic. Wear Nitrile gloves too if you're worried about getting it on your skin. It doesn't wash off, it wears off. We used to call it 'Black Death', it's nasty stuff.
    Life isn't about 'weathering the storm', it's about learning to dance in the rain.
  4. #4
    Join Date
    Apr 2010
    Location
    Corbin, Ky. USA
    Posts
    173
    Rep Power
    5
    Thanks guys! I'll try that stuff out later this weekend.
  5. #5
    Registered Member Raykreations's Avatar
    Join Date
    Feb 2010
    Location
    Greensburg, PA
    Age
    42
    Posts
    91
    Rep Power
    4
    The above advice is certainly worth taking. I've used it (3m Weatherstrip adhesive) myself and the stuff is rock solid!
    Ray...
    Graphic Designer and detail semi-freak!
Thread Information
Users Browsing this Thread
Similar Threads
  1. water based product for rubber trim?
    By link626 in forum Consumer Line
    Last Post: Jul 29th, 2010, 02:18 PM
  2. Mildew/Mold on rubber trim?
    By bigA in forum Detailing 101
    Last Post: Sep 24th, 2009, 01:07 PM
  3. Water Spot/Etching Removal and Trim Detail (by Hand)
    By volvie! in forum Show Off Your Latest Detail Work
    Last Post: Jan 15th, 2009, 03:43 PM
  4. Rubber trim?
    By rascal in forum Detailing 101
    Last Post: Apr 25th, 2006, 03:54 PM
  5. Primer overspray on rubber trim
    By mzmtg in forum Detailing 101
    Last Post: Aug 12th, 2004, 12:55 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
