Results 1 to 9 of 9
Thread: Meguiars Scratch Fix 2.0
    Registered Member Aren's Avatar
    Aug 2010
    Montreal, Quebec, Canada
    24
    3
    3
    Hey
    I'm working at Auto Parts and 1 costumer told me it was a waste of money to try repair fine scratches. I want to know who else had this bad experience?
    Thank You
    I always say, the way a man treats his car is how he treats himself.
    Registered Member Ravi_1992's Avatar
    Jul 2009
    B.C, Canada
    20
    559
    15
    Re: Meguiars Scratch Fix 2.0
    Must be a cheap non car crazy customer , I would buff fine scratches out and pay to get deep ones touched up
    Sep 2005
    14,229
    530
    It is a common complaint. Most people do not realize that there technique is lacking. It is not the product.
    Like most things in life there is a learning curve.
    Director of Training Mike Pennington's Avatar
    1,669
    28
    Quote Originally Posted by Aren View Post
    We would have to define fine scratches, and everyone has a little different idea of what that means
    That said, fine scratches are actually pretty easy to remove
    Keep in mind though....
    - Are you using the right product?
    - Are you working by hand, orbital, DA Polisher or rotary?
    - What is your skill level?
    Not sure if this helps ?
    Mike Pennington
    Director of Training and Consumer Relations
    Meguiar's, Inc.
    800-854-8073
    mpennington@meguiars.com
    Trabuco Canyon, CA
    15,724
    1074
    Quote Originally Posted by Mike Pennington View Post
    This alone can lead to some healthy debates!
    Consider that something as fine as a towel mark in the paint is, technically, a scratch and so is something as extreme as keying a panel all the way down to bare metal and you can see how determining where "fine" ends and "severe" starts can be a bit of a judgment call.
    Obviously the towel marks can be eradicated quite easily and the key scratched panel would need to be stripped and repainted. But everything in between those two will yield varying degrees of success, based largely on the variables Mike Pennington pointed out:
    Generally speaking, any scratch that you can feel with your fingernail is likely to be too deep to successfully, or even safely, remove. Even this varies, however - can you barely feel it, or does your fingernail really drop into it? If you can barely feel it then you may well be able to remove it with a bit of work. But if it's really noticeable you may be able to do no more than minimize the appearance.
    Remember, in order to remove a scratch you have to remove surrounding material down to the bottom of the scratch. After all, a scratch is missing material and how do you remove what is missing? Leveling the paint is the only way to accomplish this, but leveling to the point of removing too much clear is not a safe way to go. This alone limits how deep of a scratch you can safely remove.
    So depending on your customer's definition of "fine scratch" he may be right. Or he could be totally wrong.
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Registered Member Woodie6250's Avatar
    Dec 2007
    Johannesburg, South Africa
    197
    7
    As Mike squared have said above, the definition of a fine scratch is quite subjective and could be debated ad infinitum.
    My personal approach is to run any defect (including scratches) through the 3 R's:
    1. Remove - can I, with the tools at my disposal, completely eliminate the defect from the surface without compromising the longevity of the remaining paint layer. If the answer is yes, proceed with caution. If the answer is no, proceed to R #2
    2. Reduce - can I, with the tools at my disposal, reduce the visual impact of the defect from the surface (to the satisfaction of the customer/vehicle owner) without compromising the longevity of the remaining paint layer. If the answer is yes, proceed with caution. If the answer is no, proceed to R #3
    3. Repair/Refer - If R #1 or R #2 do not or will not satisfy the requirements of the customer/vehicle owner, refer them to a detailer who has the tools or higher skill level to achieve R #1 or R #2. Alternatively refer them to a reputable body shop to repair the defects
    In my opinion, it is never a waste of time or money to try and address any paint defects on a vehicle.
    Rally / Off-Road Nerd AWD_Junkie's Avatar
    Nov 2010
    Nashville Tennessee
    31
    6
    3
    Honestly. Any, and this is a neutral opinion I've used sever different companies products before, but Meguiars products like swirl-x scratch-x and so on, applied by hand with the right technique has saved me thousands of dollars. Application is the key, if you don't put it on right you're not going to get the results you're looking for cut & dry. Myself prefer the hand applicaton, It's like a zen thing. Getting closer to your car or truck that you have wanted forever.
    Registered Member h_bomm's Avatar
    Mar 2012
    St. Cloud MN
    169
    3
    anybody have any luck with dr. color chip? i don't have anything serious, just asking in general
    Aug 2010
    Fairmont, MN
    69
    882
    Quote Originally Posted by h_bomm View Post
    From reading (on various forums) "The Doctor" works!
    I have never used it, so can't offer anything more.
    Take a look at their web site (don't have the address), lots of info there.
    Bill
  1. #21 by hand ?
    By hardisk88 in forum Detailing 101
    Last Post: May 17th, 2006, 09:23 AM
  2. How to properly use my product ?
    By stevIW in forum Detailing 101
    Last Post: May 17th, 2006, 04:59 AM
  3. Newbie Detailing Path?
    By EddieAllen in forum Detailing 101
    Last Post: Jan 2nd, 2006, 07:34 PM
  4. Claying/waxing damaging Simoniz System 5?
    By moss in forum Detailing 101
    Last Post: Jun 26th, 2005, 08:29 PM
