Results 1 to 7 of 7
Thread: DA polisher on sharp edges
    EPHIOS EPHIOS's Avatar
    Jul 2008
    Las Vegas, Nevada
    800
    18
    How do you use (if possible) a DA polisher on sharp edges of body panels? I am mainly concern about this when I am using paint cleaners or abrasive products. I have a 2009 Scion xB, and my door panels and hood have sharp edges.
    Registered Member Ravi_1992's Avatar
    Jul 2009
    B.C, Canada
    25
    559
    20
    Re: DA polisher on sharp edges
    I would try to stay a away from the edges, you can try going really close but like you said , the corners are sharp. Going over the sharp edges can start shredding your pad ( this has happened to me ) or you can possibly go right through the paint on the edges ( maybe not because its a DA )
    Jul 2008
    Las Vegas, Nevada
    800
    18
    But, is it OK to go around CURVED panels? Later on, I will post pictures of the body panels I am talking about. Thanks!
    Feb 2010
    Suffern, NY
    26
    2,841
    52
    If you are worried about burning through the paint on the edges then you should not be worrying. When you hit an edge like that, the pad automatically slows down becasue too much pressure is put on one part of the pad hindering the rotation and stopping the cut. This is the safety clutch built into the machine.
    Registered Member Bill Davidson's Avatar
    Apr 2010
    Edmonton, Alberta, Canada
    1,166
    22
    I'm going copy & paste an excerpt from the brilliant Mr. Michael Stoops:
    http://www.meguiarsonline.com/forums...ad.php?t=43106
    Taping is done for a variety of reasons:
    • It helps prevent getting compounds/cleaner/polishes/waxes onto trim that might stain
    • The above also makes clean up a bit faster and easier
    • It helps prevent a build up these products in crevices/cracks/gaps
    • Wider tape is used to cover grilles and other openings so that a rotary buffer won't splatter product into them
    • Taping off certain pieces of metal trim can save the pad from getting ripped up by the trim
    • Tape can protect delicate trim from potential damage inflicted by a rotary, especially when using a foam cutting pad at fairly high speed
    • When panel gaps are uneven tape can protect the higher adjacent panel from getting damaged by a rotary (the paint on the edge of a panel is thinner than on the face of the panel itself and is therefore more prone to burn through)
    Some of the above applies only to the rotary, primarily those regarding trim protection, but for clean up and pad safety most apply to the D/A as well.
    Registered Member Fly Bye's Avatar
    Nov 2009
    Nor Cal
    51
    731
    16
    I would exercise caution, and use good judgement when polishing sharp edges, even with an orbital, such as a PC, Griots, G100, Flex, ect. As far as advising one on how to use a DA on sharp edges, that would depend on the particular edge in question.
    In my experiences, using a light compound/polish with a LC white, or even orange pad, I wouldn't trip on doing damage. I pretty much just glide over sharp edges with my PC. If you were to use an aggressive method, (cutting pad, heavy compound) put the machine on 6, and pressed down real hard while passing slowly, there is a possibility of doing damage.
    Sep 2005
    14,243
    535
    Just be careful. If you can't get the majority of the pad on ease up your pressure with the d/a.
  1. Meguiar's **NEW** G110 V2 Dual Action Polisher Review!!!
    By Tim Lingor in forum The Dual Action Polisher
    Last Post: Jul 5th, 2010, 03:43 PM
  2. Craigslist Ad: Meguiars G110 Dual Action Polisher Like New!! - $85.00
    By ClearlyCoated in forum For Sale or Trade
    Last Post: Jun 7th, 2009, 05:06 PM
  3. Paint Evaluation and Product Selection
    By Kevin Doe in forum Detailing 101
    Last Post: Dec 26th, 2006, 10:45 PM
  4. Product choices
    By 3JBS in forum Detailing 101
    Last Post: May 22nd, 2006, 06:55 PM
  5. Can NO one answer this Question ????
    By x02gt in forum Detailing 101
    Last Post: Jul 9th, 2005, 04:26 PM
