how to clean alternator
  • #16
    So does that mean that you hurt something else?
    • #17
      NO! I did not hurt anything I have done plenty of other engines to and there never seems to be a prolem. By the way waht kind of Jeep do you have?
      Jeff Burrows
      JB's Executive Detailing "Protecting your investment"
      • #18
        umm as the username implies ZJ= Grand Cherokee i think the viscous coupling may be going out though
        • #19
          Hey,
          Just to chime in here....
          We need to be careful; though some may not have had problems cleaning engines, there is a serious potential to do damage.
          Some companies are releasing bulletins specifying products that are non-corrosive, to prevent damage to sensitive electronics. Another problem is that with the number of different materials under the hood, using just any engine degreaser could lead to damage, particularly with aluminum in the form of chemical etching. So while the engine may appear just fine, in a short time the damage may become apparent. Further, it is not the wiring so much, but rather the sensors that are the concern. Between the O2, MAF, ECM, etc... water on any of these could spell disaster. However, it is not only these sensors. I made reference to certain Nissan engines that have recessed spark plugs as well.
          So while I love a clean engine, it would only be prudent that caution as well as every precaution should be used if you decide to clean the engine.
          Just IMHO!
          Tim
          Tim Lingor's Product Reviews
          • #20
            Just to chime in here, Tim's dead on when he says,
            Just IMHO!
            Tim
            I plan on uploading the pictures and finishing the write-up for the Engine Detailing How-To this week. Hopefully this will provide some direction as to how to work safely when detailing engine compartments.
            Mike
            • #21
              Post has been removed and poster banned due to inappropriate comments.
              [This poster is 17 years old. Please keep that in mind when he states he has cleaned engines for years]
              • #22
                Hey,
                *JeepZJlover I think everyone reading this thread should realize that you are only 17 years old, and most likely have very limited experience in detailing engines. Therefore, it would be wise for members to take advice with caution.
                Yes I have worked on many engines/drivetrains etc. My brother and father are both certified GM mechanics with a combined 49 years of experience. So, growing up in a family of mechanics does tend to have you fixing your own vehicle.
                So while the O2 sensor is screwed in, the wire going to the sensor etc may become corroded if used with the wrong cleaner/degreaser.
                Tim
                • #23
                  Self Banned
                  • #24
                    Hey,
                    Sure, you can use dielectric grease, which I do by the way. However, that is only one sensor. Plus rainstorms do not have chemical degreasers in them.
                    Tim
                    • #25
                      *** Enough is a enough. Your post has been removed due to your lack of actual experience in detailing engines. Haphazard posts on this topic could cost $1000's if someone take erroneous information and uses it themselves.
                      • #26
                        Hey,
                        Let's keep this friendly!
                        My point is that people need to use caution.
                        Tim
                        • #27
                          Removed.
                          Self Banned permantly
                          • #28
                            Good.
                            Now let's get this thread back on topic!
                            Thanks
                            Tim
                            • #29
                              on the alternator, i think the safest way of cleaning would be a scraper and some sand paper..... i wouldnt risk having to replace it because some cleaner and water got in it, and i would think a scraper and sand paper would do a good job if you have the patience
                              • #30
                                umm i think the goal here is to not scratch it up.
