Results 1 to 8 of 8
Thread: Considering first engine compartment cleaning
  1. #1
    Registered Member
    Join Date
    Aug 2008
    Location
    Central Montana
    Posts
    30
    Rep Power
    5
    I have a 2000 GMC Sierra 1/2 ton with the 5.3L V8. I'm considering cleaning the engine compartment but with all of the various components and stuff it doesn't seem possible to cover up the things that might get damaged. The coils alone are all over the place.
    How should I go about cleaning this particular engine compartment?
  2. #2
    Registered Member Still Learnin's Avatar
    Join Date
    Feb 2009
    Location
    Rancho Cucamonga
    Posts
    405
    Rep Power
    9
    Re: Considering first engine compartment cleaning
    Im not going to lie... Ive never really cover anything on an engine unless it was an exposed air filter if i do i use plastic bags and foil. you can wrap foil around anything and make it stay... my approach to engine details are as follows
    1. Mist with water to remove loose dirt (not focusing with a stream in 1 certain spot)
    2. Spray down with an APC
    3. Agitate with a brush
    4. Rinse (not focusing with a stream in 1 certain spot)
    5. Blow dry with compressor
    6. Dress engine
    7. Shut hood and start engine for 5 minutes
    8. Wipe off excess
    Good luck let us know your approach
    - Markito -
  3. #3
    Registered Member
    Join Date
    Jul 2010
    Location
    La Habra, CA
    Posts
    3
    Rep Power
    3
    I clean my engine compartment when it gets very dusty and I never cover any thing do not use any harsh cleaners as they will attack the wires I
  4. #4
    Registered Member
    Join Date
    Aug 2008
    Location
    Central Montana
    Posts
    30
    Rep Power
    5
    I appreciate the information.
    My engine has so many wires and things all over it doesn't look possible to scrub or brush anything.
    Looks like spraying with APC and gently rinsing off (i.e. not power spraying) is my best option.
    Thanks...
    Regards...
  5. #5
    Registered Member
    Join Date
    Aug 2008
    Location
    Central Montana
    Posts
    30
    Rep Power
    5
    This is a picture of my engine and all the stuff thats in the way. The other side is just as covered.
  6. #6
    Registered Member THE BIG BUFFER's Avatar
    Join Date
    Jul 2006
    Posts
    348
    Rep Power
    10
    I wash about 7-9 engines a day. I spray a degreaser and let it dwell for a few minutes. I don't scrub anything. Rince off with pressure washer and apply water based dressing, close the hood and walk away. Always looks awsome (look at my avatar) and I have NEVER had a problem with any electronics.
    Sorry Meg's but none of what I use on the engines is from Meguires. I wish i could use your products for th engines but just too hard to come by.
    "You scuff it-I buff it!"
  7. #7
    Registered Member fordf150's Avatar
    Join Date
    Jul 2009
    Location
    Hanover Minnesota
    Posts
    132
    Rep Power
    5
    Quote Originally Posted by THE BIG BUFFER View Post
    Have you ever cleaned the newer Ford Triton engines (4.6 or 5.4L modular) with your method and if you have, any issues with electrical components?
    2009 Ford F-150 XLT 4X4
  8. #8
    Registered Member
    Join Date
    Aug 2008
    Location
    Central Montana
    Posts
    30
    Rep Power
    5
    I tried some APC+ on a couple of areas of the motor compartment as a test but the APC+ had no effect on the grime. Looks like I'll have to move up to a degreaser.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Aluminum corrosion in Engine compartment
    By steve911 in forum Engine Compartment Detailing
    Last Post: Jun 14th, 2009, 01:24 AM
  2. I Love it when the engine looks new! Engine Detail 2008 Fit.
    By MDetail in forum Show Off Your Latest Detail Work
    Last Post: Nov 24th, 2008, 01:54 AM
  3. Replies: 29
    Last Post: Jun 24th, 2006, 11:45 AM
  4. Cleaning my 03 maxima's engine
    By Jason23 in forum Engine Compartment Detailing
    Last Post: May 16th, 2006, 07:26 AM
  5. Cleaning and Detailing Engine
    By kwgardner in forum Engine Compartment Detailing
    Last Post: Aug 23rd, 2005, 08:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
