Twice used in brand new condition Tornador for sale 75$ shipped!
FS: Tornador
Re: FS: Tornador
Originally posted by Autogeek
The Tornador Car Cleaning Gun is the easiest way to clean all automotive surfaces. The Tornador works with your air compressor to blast cleaning solution into crevices you can’t reach by hand. Clean carpet, plastics, and upholstery inside the car. Clean wheels, convertible tops, and body seams on the exterior. The Tornador Car Cleaning Gun cleans where other tools can’t!
The patented Tornador Car Cleaning Gun tackles your most challenging detailing jobs with ease. The cone-shaped nozzle and oscillating tip create a tornado cleaning action that cleans hard and soft surfaces like nothing you’ve seen before. Dirt and grime are immediately released from fabrics, carpet, and solid surfaces.
The Tornador Car Cleaning Gun releases a fine mist of cleaning solution that does not over saturate surfaces. You’ll see the liquid turning dirty as grime is released from the surface. Wipe with a microfiber towel. Then turn the dial to shut off the water and use the compressed air to dry the cleaned area. It’s that simple.
Use the Tornador Car Cleaning Gun on the dashboard, door panels, steering wheel, fabric upholstery, carpet, floor mats, and between seats. The Tornador cleans in tough-to-reach places between seats and in seams. Because it releases so little liquid, surfaces dry quickly.
On the exterior, use the Tornador Car Cleaning Gun to clean fabric convertible tops, body seams, wheels, and emblems. There’s no need to scrub. The Tornador does the hard work for you.
The Tornador Car Cleaning Gun must be used with an air compressor capable of producing a constant air pressure of at least 60 psi. Do not to exceed 110 psi in order to protect your Tornador from unnecessary wear.
____________________________________________________________________
