Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: 5 coats of wax??
  1. #1
    Registered Member
    Join Date
    May 2010
    Location
    SE Texas
    Posts
    8
    Rep Power
    4
    5 coats of wax??
    Hi everyone I have a waxing story/question. It allstarted 3 days ago when I was looking through the cabinet and found DC3, Turtle Wax Super Hard Shell, Cleaner Wax, Color X, and NXT 2.0. My dad only uses the Tech wax and the other waxes just sit and collect dust. So I thought why not use all of the waxes by hand starting w/ DC3, TW, Color X, Cleaner Wax, and NXT2.0 in that order. So on Tuesday I waxthe trunk and bumper w/ the waxes and I was shocked by how silky smooth the combo was (this was by hand.) I finished that up and called it a night. The next morning I washed the car to do the rest with the same combo and when I rubbed the washrag over the waxed bumper next to the unwaxed fender it was like night and day. My question is will there be any durability to the wax or will it only last a month or so in the sun (the car sits outside) The whole process took around 8 hours over 2 days and the car is 3 years old and sits out all of the time. No clay bar was used.
  2. #2
    Registered Member Fly Bye's Avatar
    Join Date
    Nov 2009
    Location
    Nor Cal
    Age
    46
    Posts
    731
    Rep Power
    11
    Re: 5 coats of wax??
    Car wax will only layer so much. Five coats of wax will not provide any benefit, other than ensuring complete coverage. Most folks will apply 2 coats to ensure complete coverage.
  3. #3
    Obsession Detailing dave93761's Avatar
    Join Date
    Aug 2009
    Location
    Melbourne, Australia
    Age
    28
    Posts
    176
    Rep Power
    5
    As Fly Bye has pointed out, 5 layers of wax is a little excessive. The LAW OF DIMINISHING RETURNS comes into play here - only so much stuff can be put down before you're simply replacing what is already on there!!!
    Also remember that ColorX and Cleaner Wax (obviously) contains cleaners, thus pretty much removing any previous layer(s) of wax laid down before it.
    I believe NXT 2.0 also has a very very very mild cleaner, but it is also a synthetic sealant; as such you shouldn't layer a sealant over a wax, rather it should be the other way round
    If you did feel compelled to do 5 layers, you'd be better off ditching the ColorX and Cleaner Wax, and just laying down 1/2 coats of NXT 2.0 and then topping it with 1/2 coats of DC3 or TW to ensure maximum protection and durability.
    Otherwise a single coat of the ColorX or Cleaner Wax (as previously stated, a secondary coat of these only removes the initial coat anyway) topped with the TW or DC3 would be the way to go.
    Good to hear it still felt awesome, but you were basically only washing over a coat of NXT 2.0....
    Hope this helps!
  4. #4
    Registered Member tguil's Avatar
    Join Date
    Feb 2004
    Location
    Southeast Nebraska
    Posts
    853
    Rep Power
    19
    Quote Originally Posted by Brentwaxer View Post
    ... My dad only uses the Tech wax and the other waxes just sit and collect dust...
    Smart dad.
    Tom
    One white Dodge Hemi, one white Toyota Tacoma, two black Harleys, and two beautiful "goldens". Life is good.
  5. #5
    Registered Member Slicked's Avatar
    Join Date
    Sep 2008
    Location
    Posts
    165
    Rep Power
    6
    Cleaner Wax followed by Gold Class liquid wax is my fav combo for a double layer.
    I agree that more than two layers is excessive.
  6. #6
    Registered Member Mary S's Avatar
    Join Date
    Feb 2010
    Location
    Lees Summit, MO
    Posts
    692
    Rep Power
    10
    The cleaner waxes, including ColorX, I am pretty sure will remove the coats underneath them, so you really should only use a cleaner wax once, and then you can layer on top of that. Whether you can mix sealants with waxes probably depends on the nature of the particular sealant. Usually a sealant is applied first and only waxes on top of it. But layers of waxes or layers of the same sealant might be of more subjective benefit than 1, and especially waxes, you would get a cumulative effect up to a point.
  7. #7
    Registered Member Keebler's Avatar
    Join Date
    Jun 2009
    Location
    Raleigh, North Carolina
    Posts
    78
    Rep Power
    4
    Try just the ColorX followed by the NXT, that is my standard process and the results are fantastic.
  8. #8
    Registered Member Garage Troll's Avatar
    Join Date
    Jul 2009
    Location
    Sinking Spring Pennsylvania
    Posts
    590
    Rep Power
    9
    I concur with the rest of the folks. 2 coats is plenty. My personal preference is 1 of NXT followed by 1 of M16. I'm not sure what the most durable combo is but experiment and find out what works for you.
  9. #9
    Registered Member
    Join Date
    Oct 2009
    Location
    In the office
    Posts
    697
    Rep Power
    10
    Great post and great points from the responders. I have learned a lot since coming here.
    At this point, if I was starting fresh where a whole process needs to be done. MOST times I always clay since it creates a better foundation for the glaze/wax to adhere to.
    So mine would be
    Clay
    "Correction if Needed"
    Glaze #7 Show Car (by hand)
    NXT 2.0 OR #26 Hi Tech Yellow (4-12 hr cure) (by hand)
    Follow Up with Ultimate Quick Wax.
    A proven combonation for me!
  10. #10
    Administrator Michael Stoops's Avatar
    Join Date
    Oct 2004
    Location
    Trabuco Canyon, CA
    Posts
    15,709
    Rep Power
    1074
    We're willing to bet the main reason you're feeling such a noticeable difference between the areas that got this "5 wax treatment" and the non treated areas is not so much because you waxed them 5 times, but because you did two treatments of a cleaner wax.
    If you used these 5 products in the order you stated (DC3, TW, Color X, Cleaner Wax, and NXT2.0) then this is essentially what you did:
    • DC3 - applied a coat of carnauba wax.
      • this literally did nothing more than put a layer of wax on the car, perhaps adding a bit of slickness and gloss, depending on the state of the paint before application
    • TW - applied a second coat of wax
      • same as above
    • ColorX - applied a fairly strong cleaner wax
      • this would have effectively removed the two previous coats of wax, plus done a good job of deep cleaning the paint.
      • this deep cleaning of the paint will go a very long toward improving the gloss and clarity of the finish, much more so than a simple coat of wax like in the first two steps.
      • the more vigorously you apply this product the more it will deep clean the paint (within limits, of course, since it's not a dedicated paint cleaner)
    • Cleaner Wax - applied an effective cleaner, though not quite as strong as ColorX
      • this would have given the paint a second cleaning, sort of a follow up or touch up of the ColorX step, if you will
      • it would have effectively removed the wax protection added by the ColorX
    • NXT Tech Wax 2.0 - applied a synthetic polish/wax
      • this would not have removed the wax protection provided by Cleaner Wax but rather added some polish and long lasting, 100% synthetic protection.
    Now, we don't really want to be so harsh as to say that your first two steps were a waste of time, but in the context of the whole process you did, they sort of were. After all, your third and fourth steps pretty well negated any effort and result from the first two.
    In future, after a proper wash/dry, inspect the finish carefully in strong, direct light. Feel it with your fingertips. If it feels rough, clay it. If not, don't bother. If you see very fine swirls or towel marks, then use the ColorX with a bit of passion behind the pad, and then follow up a coat of NXT. If you don't see any such minor defects, then just to straight to the NXT. But remember, two thin, uniform coats!
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Please post technical questions directly to the forum rather than emailing or PM-ing me. You
    will get a faster response on the forum, and your question could help someone else, too!
Thread Information
Users Browsing this Thread
Similar Threads
  1. How many bottles of car wax do you have?
    By EPHIOS in forum Consumer Line
    Last Post: Aug 19th, 2010, 07:32 PM
  2. Old article from 1994
    By alkemyst in forum The Break Room
    Last Post: Mar 18th, 2008, 03:01 PM
  3. What's the difference between Meguiar's waxes?
    By Comanche in forum Detailing 101
    Last Post: May 25th, 2005, 06:15 PM
  4. Wax Differences
    By 94gpse in forum Detailing 101
    Last Post: Mar 21st, 2005, 02:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
