Is it true that Last Touch contains silicone's ?
Does Last Touch contain silicones?
Re: Does Last Touch contain silicones?
I think that it may as it is not body shop safe. I know that silicone should be no where near a paint booth as it could cause fisheyes in the paint; if I heard properly. For regular application I do not think it makes a difference.Tedrow's Detailing
845-642-1698
If you're in a body shop environment you will want to avoid this product. Otherwise, there's nothing in it that can cause any sort of issues for you.Michael Stoops
Originally posted by Michael Stoops View PostIf you're in a body shop environment you will want to avoid this product. Otherwise, there's nothing in it that can cause any sort of issues for you.
Originally posted by Mark Kleis View PostJust curious, why are you trying to find out?
Is there a type of silicone you are trying to avoid?
the reason why i would like to know is the following : someone ( a pro-detailer) on a detailingforum over here in Belgium ,states that Last Touch leaves a greasy film on the paint after claying ,because of the silicones in Last Touch
Something i have never experienced!
He also states that before polishing,you have to remove that film by using a cleaner ,or it will affect the result of the polishingstage in a negative way.
Also something i have never experienced !
I decided to do a test on the hood of my Alfa .
- washed with NXTshampoo & washmitt
- clayed with consumerclay & Last Touch
- dryed with watermagnet
- cleaned half of the hood with IPA ,left the other half untouched
- then polished with the rotary & m83 & polishingpad (Meguiars w8007)
- then finished with DA & m80 & w8007.
- after polishing i cleaned the entire hood with IPA to remove all polishingoils from the paint so i could evaluate the result and see the true state of the paint.
I could not see any difference ,both sides of the hood were clean,shiny,smooth even under halogenlighting (brinckman) and in direct sunlight !
Probably just had a film from not removing it all when claying. You tend to use more of the spray when claying then when just dusting.
It is also recomended to be diluted 1:1 for claying, which would help with that.2017 Subaru WRX Premium - WR Blue
I use Last Touch exclusively and have never noticed any film or streaking. Probably another myth that starts to spread like wildfire.
ColinA common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
Originally posted by cnfowler View PostI use Last Touch exclusively and have never noticed any film or streaking. Probably another myth that starts to spread like wildfire.
Colin
The sad thing is that people believe him without seeing it for themselves just because he is a pro-detailer !
Got pulled away for a while there guys, sorry.
Yes, there is indeed some silicone in Last Touch, but in the overall scheme of things it shouldn't be an issue at all.
Colin, the issue described by the poster in the forum that geert dr mentions may very well have been experiencing some rare issue, and not necessarily spreading a myth. There are rare cases where anything with silicone in it can have some impact on the buffing cycle, but it is extremely rare. Since a mist & wipe product isn't really bonding to the surface like a wax does, and most waxes contain at least a little silicone as well, it should all come off quite easily. Interestingly enough, a couple of years ago we had a regular attendee at our Thursday Night Open Garages observing a weird film on the surface of his non metallic black car. You could literally leave streaks in the finish with your fingertips, and 15 minutes later the streaks were gone, as if they'd been filled in or something. It seemed that almost any mist & wipe product he tried was exhibiting this exact same phenomenon. It did, however, come off very easily even with just Deep Crystal Paint Cleaner.
Sometimes we just see paint respond in weird ways, but just because something is a problem for one person (or even just a perceived problem) doesn't mean it's going to be a problem for another. geert dr's test would seem to prove this since he noticed no difference at all between the different sides of his hood. So on his car, with the products he uses, it's a non issue. Why this other person would have the problem he did is hard to say, however, since virtually any typical clay lube (quick detailers, mostly) are going to have some silicone in them. With the exception of M34 Final Inspection, all of ours do.
What is a potential issue, however, is products with very durable polymers. Sometimes trying to get those fully off the surface can be a bit of a task in itself. Sure, you can eventually get through them with a machine applied paint cleaner, but until they're gone you might think your paint cleaner isn't working all that great. How "durable" are some of these durable polymers? Enough so that even some wet sanding processes won't get through them immediately. Crazy as that sounds, our new sanding and finishing discs are essentially a slurry bonded to the disc, with a protective layer (induction layer) on the surface to protect the slurry prior to use. When first putting these discs on the paint it takes a couple of strokes to get through that induction layer and start cutting. With a serious coat of durable polymer present on the paint, the induction layer just doesn't want to break down and the sanding discs look like they're doing almost nothing at all. Sanding discs!!! Silicone can slow down that process too, but not to the degree that durable polymers will. Even so, it's almost crazy to think that you can slow down the effect of sanding with these ingredients, but you can.
Still, for the vast majority of cases, you shouldn't have any real issues using a mist & wipe product that contains some silicone. As mentioned earlier, the silicone content is fairly low and the product isn't bonding to the surface like a wax or sealant.Michael Stoops
