Before I begin asking my question I'd like to say "hi" because I'm new on this board.
So to get started...
I have the impression that if you use SwirlX to do a spot repair it is more aggressive then ScratchX?
Last weekend I fixed a new scratch on my rear bumper with swirlX alone. I took me 3 hits by hand and I didn't use a lot of force on the foam pad at all. I started with SwirlX because I want to start with the least aggressive product first but I was impressed by how little effort I had to put into it! I just worked in the product untill it broke down, no hard pressure applied.
Could this be possible because SwirlX is meant more to treat bigger areas and scratchX is typically used to fix up local paint defects? So if you would use SwirlX on just a small surface it will pack a bigger punch then ScratchX? If that is true then this means I started with the most aggressive method, I should have started with ScratchX then. Sure I'm happy to have the scratch fixed, but I don't want to take away more clear coat then needed!
This is just a theory and might be rubbish...
Can any expert comment on this?
