I have a 1990 corvette with a steel blue metallic finish. On the hood, right above the drivers side wheel, if you look at the paint at a sharp angle, there is what looks to be likea 'hazyness' or 'foggyness'. I have tried using a machine polisher with a foam pad and some meguiars swirl remover, but it doesn't seem to help much. I'm not even sure what could have caused this, but i admit that it is difficult to see unless you look at it at the proper angel. Do you know of any product that will help remove this defect or if it is simply age that has caused the clearcoat to haze in this one specific area? Could it have been caused by my polisher?
Also, on the top of the rear of the corvette, there is what looks to be the remains of water spots, but I suppose I'll just use some scratchx or some cutting compound to remove that, if that is what you recommend. Again, you must look at the right angel, but they are there and i'd like to remove them to restore this finish.
If you have any suggestions on any products to use or techniquse to try, I will do my best to try them!
