Gilmour Foam Gun require pressure washer?
  • Gilmour Foam Gun require pressure washer?
    Anyone know if this foam gun http://www.autodetailingsolutions.net/75qgfmr.html requires a pressure washer.
    From the attachment in the picture and that it says that 40-60 psi will yield the best results I would assume not. Thanks in advance!
    Tedrow's Detailing
    845-642-1698
    Re: Gilmour Foam Gun require pressure washer?
    The Gilmour Foam Gun just uses a regular hose.
      Normal water pressure in most homes is between 40 - 80 psi.
      Foam gun will work just fine on the garden hose.
      Power washers usually raise pressure to 1000 - 3500 psi.
