Hard Water Spots
Results 1 to 10 of 13
Thread: Hard Water Spots
    Mar 2010
    Naples. FL
    6
    9
    Hard Water Spots
    What product do I use to remove hard water spots?
    Feb 2009
    Powell, Tennessee
    30
    3,543
    130
    Re: Hard Water Spots
    to MOL!
    What are you working on? Paint? Glass?
    Sep 2005
    14,242
    535
    On glass I have had much success with #4. Heavy cut cleaner.
    On paint #105. or #4 again.
    Welcome to mol.
    Mar 2010
    Naples. FL
    6
    9
    Black paint
    Nov 2009
    South TX
    192
    thoroughly wash the car (2 bucket method) - clay it - do a small test spot working with the least agressive product working yourself up to the most agressive.
    Have fun.
    Mar 2010
    Naples. FL
    6
    9
    Sorry, I'm new to this what is #4 and #105?
    38
    19,005
    234
    #4 and #105 are both paint cleaners.
    If you are working by hand, here is what I would do:
    1. Wash
    2. Clay
    3. Clean - You will want SwirlX and Ultimate Compound. Try SwirlX first on a test area, then move to UC if needed.
    4. Wax - 2 thin coats of your favorite wax.
    Sep 2005
    14,242
    535
    Since your doing this by hand. Start out with the swirl-x. Then re evaluate the surface after. If you still need more cutting power. Step up to the Ultimate Compound.
    Sorry did not mean to confuse you in my first post. Good luck.
    Trabuco Canyon, CA
    21,351
    1135
    Water spots can be pesky buggers. They run the range from light enough to remove with a quick detail spray to stubborn enough to require rotary buffing to remove, and everything in between. That's true whether on glass, paint, plastic, whatever.
    You have the extra challenge of working on black paint, where your applicator choice can play a huge role in the final outcome. Stay away from terry cloth as this material is aggressive enough that it alone can haze the paint. Use a soft foam wax applicator pad and some Ultimate Compound (available at most auto parts stores), working in small areas (about 1 foot square) with moderate to heavy pressure, and wipe the product off while still wet (allowing it to dry serves no purpose and could just make it difficult to remove). Depending on how stubborn the water spots are you might need a second application, or even a third, to fully remove them. Apply a thin coat of your favorite wax to the treated areas.
    Mar 2010
    Naples. FL
    6
    9
    Turns out I had more issues than the water spots. The car is a Black 2003 Lexus ES 300 with low mileage, 25,000. I orginially leased the car, but decided to buy it at the end of the lease because of the low mileage. Because of this history I didn't give it the paint care it needed. The surface was really rough. I started with one coat of the Ultima, but this didn't remove the rough surface or water spots. I next used Clay. This smoothed the surface and reduced some but not all of the water spots. After the Clay I applied a coat of Ultima and it got rid of most, but not all water spots. Sounds like I need to apply a second and maybe third coat of Ultima.
    I should have said more about myself in my first Thread. I owned a Black used 1982 Porsche 911 for seven years, which I gave the full Mequiar's treatment. Since I sold it I have been leasing cars so really didn't do anything special. Last summer I purchased a new Honda S2000 CR. I been using Mequiar's on it, but since it's new haven't done a lot with it yet except wash, wax and leather treatment.
  1. Re: Some conversation between Kevin Brown and Barry Theal
    By Kevin Brown in forum The Dual Action Polisher
    Last Post: Jan 23rd, 2010, 09:55 AM
  2. Replies: 5
    Last Post: May 8th, 2008, 08:46 AM
  3. water spots
    By SpeeDRaceR in forum Detailing 101
    Last Post: Jun 6th, 2006, 10:28 PM
  4. little problem here, lots of water spots
    By maxima2k2 in forum Detailing 101
    Last Post: Mar 10th, 2006, 07:11 AM
  5. hard water spots
    By MonicaBolero in forum Detailing 101
    Last Post: Sep 6th, 2005, 08:33 AM
