Wash and Clay in 1 Step - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Wash and Clay in 1 Step
  1. #11
    Registered Member jarred767's Avatar
    Join Date
    Jan 2007
    Location
    Bend, OR
    Age
    34
    Posts
    687
    Rep Power
    18
    Re: Wash and Clay in 1 Step
    Does the Nanoskin wash mitt mar the paint at all? I kind of use the same type of method with the Speedy Prep Towel, but find that it has a tendency to mar the paint (actually almost looks similar to a very very light wet-sand). When I'm doing a full detail, it's not a big deal as that dullness easily polishes out, but if I'm just doing a wash and wax, I have to dry and use a clay lube and all and it just takes longer. How many cars do you feel like you can do with the Nanoskin too?
    Dynamic Detailing
    541.668.0480
  2. #12
    Registered Member Dellinger's Avatar
    Join Date
    Mar 2013
    Location
    Amboy Washington
    Posts
    67
    Rep Power
    6
    Quote Originally Posted by Meticulous-Detail View Post
    Foam cannon makes it real easy, nice thick suds. I use chemical guys citrus wash n gloss. This soap is used for stripping wax and sealant, when combined with the nano skin wash mitt you get a squeaky clean smooth finish.
    Hmmm... I always get confused with CG's soaps... why does it have 'n gloss' at the end? (Don't expect you to really answer that, lol.) Have you ever tried Hyperwash? I'm thinking about picking it up or CG's Bug/ Tar soap as a heavy duty maintenance or pre-correction wash. But I want to try the nanoskin with foam to see how it performs and assume a wash with some good lubricity is key.
    Quote Originally Posted by jarred767 View Post
    Yes, I have had the Nanoskin mar the paint... especially on soft paint systems (Honda, Toyota, etc...) and even on medium hard dark colors. REALIZE, I wasn't using the recommended Glide lubricant that Nanoskin recommends. I was using CG Luber (got it for $10 a gallon so I tried it out... last time with that stuff!)
    One of my production oriented packages that includes a wash/decon/wax utilizes an cleaner wax, machine applied with a finishing pad, to clean up any light marring left by the decon.
    I haven't tried the foam cannon + nanoskin yet... but I have a feeling this may be the better option as Meticulous has alluded to.
  3. #13
    Registered Member
    Join Date
    Feb 2017
    Location
    Philadelphia, pa
    Posts
    21
    Rep Power
    2
    Interesting ideas, I try to make things easy by:
    Foaming the car
    Two Bucket wash
    The take the soap from my two bucket wash and use that as lubrication for my clay bar.
    Works great and no clay lube needed.
  4. #14
    Registered Member HCAD's Avatar
    Join Date
    May 2009
    Location
    Lynchburg, VA
    Posts
    447
    Rep Power
    14
    Quote Originally Posted by J. A. Michaels View Post
    Also, I believe you are shortening the lifespan of your claybar. By just using water to clay.
    In reading DetailArtist comment, he IS using a clay lube. My Meguiar's clay lube that I use is mixed from a concentrate with, you guessed it, water. So, I don't see where this will shorten the life span of the clay.
    Quote Originally Posted by Tuck91 View Post
    That might work on a show car but for a daily driver or a panel with overspray on it you have to really work the clay against the finish and keep the panel properly lubricated while you are doing that.
    When claying directly after a wash, it's not likely that the paint surface will remain flooded with water. If it's an unwaxed "daily driver", it's likely that the water will dry up rather quickly. But again, as I mentioned above, the clay lube is a large percentage of water. The additional water on the paint surface after a wash isn't a hindrance. It's just more of what you're spraying on with the clay lube. If you want to feel like you're getting more lubrication, you can mix the lube 60/40 or 75/25, with the clay concentrate as the higher percentage. (Meguiar's Last Touch is mixed 50/50)
    Quote Originally Posted by DetailArtist View Post
    After washing the car, don't dry it, spray your clay lube on the car while its still wet, clay it, rinse again, (and lower the windows at that point so the top inch gets cleaned) THEN you dry it.
    My process exactly! Saves tons of time verses drying, then claying, and drying again.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 23
    Last Post: Dec 1st, 2010, 04:26 PM
  2. Learning to use the Rotary Buffer
    By Mike Phillips in forum How To Articles
    Last Post: Apr 29th, 2010, 10:15 PM
  3. Wax Job- 06 Monty Red Vette
    By vettemaniac in forum Show Off Your Latest Detail Work
    Last Post: Sep 5th, 2006, 05:32 PM
  4. My Meguiar's Detail Clinic Article was Printed!
    By tekygeek in forum Detailing 101
    Last Post: Nov 28th, 2005, 09:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
