Results 1 to 10 of 14
Thread: Wash and Clay in 1 Step
    Registered Member DetailArtist's Avatar
    Mar 2010
    ny ny
    72
    8
    After washing the car, don't dry it, spray your clay lube on the car while its still wet, clay it, rinse again, (and lower the windows at that point so the top inch gets cleaned) THEN you dry it.
    Jan 2009
    New Lenox, Illinois
    10,362
    298
    Re: Wash and Clay in 1 Step
    That might work on a show car but for a daily driver or a panel with overspray on it you have to really work the clay against the finish and keep the panel properly lubricated while you are doing that.
    Sep 2005
    14,243
    534
    Also, I believe you are shortening the lifespan of your claybar. By just using water to clay.
    Mar 2010
    ny ny
    72
    8
    Gee, and I thought the paint contaminents like overspray, tar, bugs and fallout used-up the clay!
    Jun 2005
    The Real NorCal
    4,029
    140
    They don't use up the clay, they fill-up the clay which should be discarded after it gets too "dirty."
    Jetta TDI DogParkGuy's Avatar
    Dec 2005
    351
    17
    Quote Originally Posted by DetailArtist View Post
    That is what I do! Except I soap and rewash the exterior again. Takes longer but assures the surface is clean.
    Art Layton
    2009 Jetta TDI
    Jan 2014
    honolulu,hawaii
    23
    4
    Yes, good idea. I wash the car first. then using the soap and water (assuming we all do the two bucket system) I use the soap and water mixture as lubricant for my claying step. This saves money on the detailer spay and I know other detailers do this also. Of course I won't reuse that same clay on other cars.
    Nov 2009
    Stang Island, NY
    791
    15
    If your are going to use soap and water the Nanoskin Wash Mitt is what you want. Wash, don't dry, use the Nanoskin Wash Mitt as directed, then dry. I do this on all my details as it works well and saves time.
    Registered Member Dellinger's Avatar
    Mar 2013
    Amboy Washington
    67
    5
    Quote Originally Posted by Meticulous-Detail View Post
    Meticulous... what shampoo are you using for the Nanoskin? I assume you are using a foam cannon also?
    Thanks!
    -Dellinger
    Nov 2009
    Stang Island, NY
    791
    15
    Quote Originally Posted by Dellinger View Post
    Thanks!
    -Dellinger
    Foam cannon makes it real easy, nice thick suds. I use chemical guys citrus wash n gloss. This soap is used for stripping wax and sealant, when combined with the nano skin wash mitt you get a squeaky clean smooth finish.
  1. Replies: 23
    Last Post: Dec 1st, 2010, 04:26 PM
  2. Learning to use the Rotary Buffer
    Last Post: Apr 29th, 2010, 10:15 PM
  3. Wax Job- 06 Monty Red Vette
    By vettemaniac in forum Show Off Your Latest Detail Work
    Last Post: Sep 5th, 2006, 05:32 PM
  4. My Meguiar's Detail Clinic Article was Printed!
    By tekygeek in forum Detailing 101
    Last Post: Nov 28th, 2005, 09:32 PM
