Hi, with the rotary buffer, will it make much difference if I use the 6.5 backing plate with the 2.0 pads, or should I get the 7-inch one. The difference is I can get the 6.5 one quite a bit cheaper, around $10 on Amazon.
Can I use a 6.5 backing plate with 7" 2.0 pads?
Re: Can I use a 6.5 backing plate with 7" 2.0 pads?
While you can use the W65, you just won't get the maximum benefit of the W68 / 2.0 pad combo as they were designed.
Mike Pennington
Meguiar's, Inc.
800-854-8073
mpennington@meguiars.com
The W68 (5.75" backing plate for our 7" 2.0 foam pads) will work on a W4000, you just won't have the centering button...
You reference the W4000 as a 6.5" pad...The W4000 is a 8" wool pad ?Mike Pennington
Meguiar's, Inc.
800-854-8073
So for the W4000, would you normally use the backing plate made for the 8" pads?
I didn't find a similar wool pad to go with the 7" plate.
Originally posted by Marcki View PostSo for the W4000, would you normally use the backing plate made for the 8" pads?
The only downside is you lose the centering button, but just look carefully when you are attaching the wool pad, and you will be ok
Mike Pennington
Meguiar's, Inc.
800-854-8073
Anytime, that's what we are here forMike Pennington
Meguiar's, Inc.
800-854-8073
