How to remove tar from non-painted plastic trim?
  • How to remove tar from non-painted plastic trim?
    As in the subject.
    I haven't tried GC BT Remover though, as I red somewhere in this forum, GC BT Remover will leave white stains when used on plastic trim.
    Thanks!
    Re: How to remove tar from non-painted plastic trim?
    Have you tried a degreaser?
      You could look at clay, APC, a degreaser, Bug and Tar Remover, Dawn.....
        Clay bar would be my least f option. The trim is located ar bottom side of the body. The clay will pickup so many dirt that I have to trash after using it.
        Is a degreaser mean an engine degreaser? Is it safe on plastic?
        Still looking for inputs, making sure I dont mess with the trim.
        thanks.
          Sometimes i use liquid paraffin,it kinds of melts the tar away no rubbing is required.But i think that a specially ment product would be better.
            I've never had APC stain my wheelwells or anything, or Bug and Tar stain anything, so I wouldnt be too worried. Dont leave it sit for an hour of course.
            And you can always do a small, out of the way test spot first.
              Hi CA 999
              WD40 will remove the tar in a flash. Use a paper towel to remove the residue and then wash the area to get rid of any film and the WD40 smell.
              Try it ... it will work.
              Have a good evening.
              Harry
              2004 Toyota Tundra Limited V8 Dark Met. Green
                More a citrus-type or Dawn degreaser as opposed to an engine degreaser, but try the wd40... sounds like it may be an easy solution.
                  How about #M39 or #M40?
                  Can both use to clean tar on plastic?
                  thanks.
                    What kind of car is this on? Tarminator or body solvent should be fine for non-painted plastic.
                    Rasky's Auto Detailing
                      It is a Suzuki SX4. Got black plastic trim on underside all over the body.
                      Thanks for the input guys. I think I'll try the WD40.
