I know there have been posts about these two spray products and that there is an overwhelming preference for the UQW among posters. I wanted to present a different experience.
I have a car that is garaged and driven very little and I generally "California dust" it and clean it with UQD when putting it away. I have also used UQW after the UQD every fourth or fifth time and this regimen has prevented my having to do any claying, paint cleaning or conventional waxing for the past six months.
I had a bottle of NXT spray in the garage and I used it about a month ago on my everyday, parked-outside car. I was surprised by both the good appearance of the surface, the apparent thickness of the coating (compared to UQW) and the durability. It also leaves a slicker, waxier feel than the UQW.
So I tried it on the right half of my garage queen and continued using UQW on the left side of the car. I am very impressed with the NXT spray. I find the surface a very tiny bit less glossy than the UQW, but it has a much deeper color on this black car. It is more natural looking and gives the paint an appearance of body that it does not have with the UQW. The NXT also gives a perfectly even, streak-free surface. (Even used very sparingly, the UQW always shows some uneveness of surface in my experience.) In comparison, the UQW side looks very shiny, but not waxed. The NXT side almost looks like it has a coat of carnauba on it--that's what I mean by "body."
The two products are slightly different in use. The UQW can be used in the sun and on black plastic trim and glass and is a mist and wipe product. The NXT spray is a mist-let haze-wipe product and has to be kept off black, porous trim much like a conventional wax. I spray it on the microfiber pad in smaller areas to keep it off the trim, glass, etc. After hazing, which is very fast, the wipe off is extremely easy. I don't find the NXT more difficult or time consuming to use and it doesn't require the extremely careful application of UQW to reduce streaking. Applied with a microfiber pad, the NXT also seems to provide some cleaning if the appearance of the pad is worth anything. The UQW doesn't provide any cleaning effect at all in my experience.
If you don't mind the different application techniques and the not-on-everything limitation of the NXT, I suggest you try it. For the way I take care of the car I am finding it a much better choice than the UQW. It is better looking to me and it appears to be more durable.
The UQD, on the other hand, I'd hate to give up.
