Re: Product, Pad and Speed settings for the G110 Dual Action Polisher - Updated!
8" pads are generally reserved for rotary use, where the higher speeds achieved at the outer perimeter of the pad will increase cut. On a DA that large pad will overwhelm the tool and, as you've experienced, you won't get anything done.
We see plenty of folks stating on other forums that our 7" Soft Buff 2.0 pads are too large for DA use, but looking at all the cars we've corrected in our Saturday Classes using these pads, all the demos we've done, and all the real world cars we've done full corrections on, we just don't see them as being a negative in any way. We do highly recommend that you pair these pads with our W68DA backing plate, however, to get max results. 4" pads are great for spot work, but they really concentrate the energy of the DA into a very small area and that can be an issue on urethane bumper covers and other plastic substrate pieces - especially when working in a very aggressive manner. Working with the 7424XP you may find that you need to run at slightly higher speeds than what we generally recommend with our G110v2 just because the XP doesn't have quite the torque level of our tool and it will bog down quite a bit easier under pressure.
Now, we know that you'll likely to get several recommendations for LC's range of 5.5" pads, and that's fine. They're excellent pads, no doubt about it. But if you want to stick with Meguiar's products, we'd suggest going with the 7" Soft Buff 2.0 pads rather than the 4", and concentrate on your buffing technique to get the job done.
