Crank up/Pop-Top camper trailers?
Results 1 to 7 of 7
Thread: Crank up/Pop-Top camper trailers?
  1. #1
    Registered Member CumminsCrazed's Avatar
    Join Date
    Apr 2009
    Location
    Mason City, Iowa
    Age
    36
    Posts
    914
    Rep Power
    46
    Hey guys, do you know if this style camper is a gel coat finish, or car paint type of finish or what. Id like to clean ours up but im unsure of what line of product to reach out for. Heres a few pics of ours so you have an idea.
    Pics to come shortly...my photobucket isnt working!
    Zach Hall
  2. #2
    Join Date
    Oct 2004
    Location
    Pittsburgh, PA
    Age
    41
    Posts
    19,269
    Rep Power
    239
    Re: Crank up/Pop-Top camper trailers?
    Just as FYI, you can use paint products on a gel coat, but not gel coat products on paint.
    Gel coat is generally harder /thicker, so it needs/can take stronger products. But those products would be too strong for paint.
  3. #3
    Registered Member kaptain_zero's Avatar
    Join Date
    Apr 2009
    Location
    Winnipeg Manitoba Canada
    Posts
    105
    Rep Power
    18
    Unfortunately. it's all over the map, material wise, on pop up campers. My previous two Starcraft models had painted aluminum all around including the roof. The one I have now (a 2005) has a fiberglass roof which means gel coat. Having said that, and as already mentioned, you can just use stuff made for cars.... I like good old A12 cleaner wax and I add a second coat of the nearest can of paste wax. I've also been very happy with Duragloss 501 Marine & R/V Polish (it's a cleaner wax, much like A12) and it works very well on fiberglass as well as regular painted panels. I use it on my car's clear coat wheels and it's quite well spoken of on other detailing forums. I'll reach for whichever bottle is closer when I'm going to do a base layer on the Starcraft when I want some cleaning power.... Megs is available locally so I'll stick with that when the DG 501 runs out. If it turns out you have fiberglass and it's quite chalky..... I'd probably look at a gel coat specific product *IF* a basic cleaner wax won't do the trick. The thing is.... I don't think I've ever seen a pop up that was completely fiberglass.... most are made of a combination of materials so sticking with a paint safe product is the way to go if things are in pretty good shape.
    Regards
    Christian
  4. #4
    Join Date
    Apr 2009
    Location
    Mason City, Iowa
    Age
    36
    Posts
    914
    Rep Power
    46
    ok....heres the pics i was speaking of earlier, for what its worth, its a 1998 Jayco Eagle 8 camper
    Zach Hall
  5. #5
    Join Date
    Oct 2004
    Location
    Pittsburgh, PA
    Age
    41
    Posts
    19,269
    Rep Power
    239
    Looks like an "if you dont know, start with some paint care products", as mentioned above.
  6. #6
    Join Date
    Apr 2009
    Location
    Posts
    105
    Rep Power
    18
    Well, she's looking quite clean from what I can tell in the pictures. If I had to guess, I'd say that the siding is all painted aluminum sheeting, and with that seam on the roof panel, it very likely painted aluminum as well. I'd go with a cleaner wax such as one of the ones I mentioned previously. No need for special stuff. If you have something like liquid NXT kicking around, you can always use that but I'd go with an inexpensive cleaner wax like A12 and then use the good stuff later if you must.... The thing is, it's going to get dirty with lots of tree sap and the like unless you only camp in the dessert so frequent cleaning/waxing will be needed if you want to keep the exterior looking good, and if you're doing it frequently, why use an expensive wax made to last a long time?
    Christian
  7. #7
    Join Date
    Apr 2009
    Location
    Mason City, Iowa
    Age
    36
    Posts
    914
    Rep Power
    46
    ok cool man, thanks!!
    Zach Hall
Thread Information
Users Browsing this Thread
Similar Threads
  1. Replies: 4
    Last Post: Oct 2nd, 2008, 06:58 AM
  2. Canvas Top - Convertible Top - Which products to use?
    By Mike Phillips in forum Hot Topics & Frequently Asked Questions
    Last Post: Aug 16th, 2008, 08:32 AM
  3. Top Fuel Tidbits...
    By Kevin Brown in forum The Break Room
    Last Post: Feb 26th, 2008, 11:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
