Results 1 to 10 of 16
Thread: How to remove epoxy from paint?
    Mar 2009
    NorCal
    23
    I was fixing a cracked fairing on my bike and I epoxied it (quick set). Tried to remove the leftovers with a sponge. the sponge kind of disintegrated. so now it looks like there's a smear of dirt/bird **** stuck to it.
    Im pretty sure its single stage paint if that helps.
    Any idea how to get this off?
    'Pearly Gates' Eddie6th's Avatar
    May 2009
    Italy
    3,169
    88
    Re: How to remove epoxy from paint?
    These 'qiuck setting' resins are extremely tough when dried.You have to sand them down.That's why your sponge disintigrated.
    I take it you are reffering to a 2 compound mixture,which is used in bodyshops.Normally reffered to as 'filler'.
    57
    24,796
    517
    Quote Originally Posted by finebykris View Post
    Very carefully.
    Seriously, there's a number of things you can try, can you post a picture?
    Is the bond strong where the epoxy is not supposed to be? If not maybe you can carefully scrape/chip it off with a plastic razor blade?
    Anything strong enough to dissolve the epoxy would likely be strong enough to dissolve single stage paint so strong liquid solvent are probably not going to work.
    You could try carefully sanding it off? First place blue painters tap on all the surrounding paint so that when you sand you don't put scratches in good paint.
    We have these sanding blocks for removing dirt nibs and paint runs in new paint jobs that's a possibility?
    Mar 2009
    NorCal
    23
    its just the 5min quick set epoxy with the 2 liquids you mix.
    I'll try sanding, hopefully it works.
    May 2009
    Italy
    3,169
    88
    I know what stuff you mean.There are a lot,but they all basically do the same thing.Unfortunatley,it has set where your intention was to wipe away the excess.(In hot weather they can set even quicker. You can only try what Mike has suggested to you..
    It would help,if you could upload a pic of it.
    Mar 2009
    NorCal
    23
    Here are some pics.
    and sanding is going to be really hard to do because of the shape of it. plus im sure i will end up sanding into the paint, which I dont want to do. theres got to be something that will remove epoxy but not paint
    57
    24,796
    517
    Maybe sand it smooth and put a really cool sticker on that area?
    Or sand that section down and have a local paint store mix you some paint and put it in an aerosol can for you.?
    Maybe some Emery boards, like girls use for their fingernails?
    Just a few ideas...
    May 2009
    Italy
    3,169
    88
    Hi.I've had a look at your pics.I think I know what kind of stuff you have used.Is it a metal alloy compound? You normally get 2 tubes and squeeze them together and mix?
    Mar 2009
    NorCal
    23
    It seems like chipping it with a old credit card is pretty effective albeit painfully time consuming.
    Im going to try to use a peice of plexiglass because it keeps destroying the old credit cards.
    May 2009
    Italy
    3,169
    88
    Is it coming off okay,without damaging the paint? If it's working okay,that's good.
  1. How To Remove Water Spots
    Last Post: Aug 29th, 2017, 08:25 AM
  2. Water Spots Galore
    By 100kdown in forum Detailing 101
    Last Post: Aug 19th, 2008, 02:02 PM
  3. Replies: 5
    Last Post: May 8th, 2008, 08:46 AM
  4. Recommendations plzzzz
    By Rowen in forum Detailing 101
    Last Post: Mar 2nd, 2006, 10:52 AM
