Results 1 to 10 of 10
Thread: No petroleum tire protectant
    Jun 2009
    Hesperus, CO
    4
    9
    Question No petroleum tire protectant
    Does anyone know if Meguiar's makes a tire protector that does not contain petroleum products. I was told that I would need a product like this for my RV tires to prevent cracking a splitting.
    Thanks
    57
    24,796
    517
    Re: No petroleum tire protectant
    I'll check on your request until then the problem your describing isn't a problem related to petroleum products used in tire dressings.
    From our Frequently Asked Questions.
    Most people don't give a lot of thought to their tires except for how they look. Truth be known, your tires are designed to perform under extreme conditions of heat via kinetic energy transfer, high speeds for long periods of time and incredible forces of torque and flexing. That's a lot to ask from a chunk of rubber, inflated with air like a cream filled donut.
    The science behind the modern rubber formulas used by major tire manufactures today is both complex and interesting. The rubber itself contains and ingredient called Antiozonant.
    Antiozonant is an ingredient that helps to prevent the exterior rubber surface from cracking, checking, oxidizing, and deteriorating. The rubber is designed in such a way as to constantly work its way to the outside of the tire and as such, continually replenish the exterior surface with fresh antiozonant.
    After the antiozonant works its way to the outside of the tire and is exposed to the ozone in the air, it turns brown. The technical term for this effect is blooming.
    This is why you see a brown film on the surface your tires. You can wash your tires with soap or an all-purpose cleaner and remove this film, but in a few weeks, it's back. That's because the antiozonant continually works its way to the outside of the tires every time you drive your car.
    Thus before applying a dressing you really need to do a thorough job of cleaning the outer surface of the tire to remove any spent antiozonants as well as any previously applied dressing and this will prepare the rubber to accept a fresh application of tire dressing.
    Meguiar's Tire Dressing Options
    To maintain your tires and keep them looking sharp with a deep, dark black color, Meguiar's offers six unique tire dressings that treat the rubber with Meguiar's own special conditioning agents as well as patented antiozonants that replenish your tires' original antiozonants and keep your tires looking blacker longer than generic tire dressings and protectants.
    Special polymers actually penetrate and cure to the surface to form a long lasting barrier-film that protects your tires from inclement weather and exposure to corrosive elements.
    Meguiar's tests all their products to be safe for the surface they are formulated to be used on as long as the products are used according to directions.
    Jun 2009
    Hesperus, CO
    4
    9
    Thanks Mike I will be looking for your response.
    57
    24,796
    517
    Okay, here's the skinny....
    First, it needs to be clearly stated and understood that Meguiar's tire dressings are completely safe for use on tires no matter what the ingredients as our Chemists understand the importance of safety as it relates to tires on your cars, trucks, s.u.v.s and yes, Motorhomes.
    The true problem with cracking and blooming, (blooming = browning of the surface), is the result of exposing the rubber to the sun, air and moister.
    The problem is not caused by or accelerated by any of our tire dressings, in fact just the opposite, the deterioration process is slowed down with the use of our products.
    That said, here is a list of dressings that can be used on tires that contain no petroleum products. Note that these are all water-based and as such don't have the longevity of some of our other dressings.
    Also, all three of these products are in our Professional Line, not our Consumer Line. What that means to you is you won't find these products in Walmart, Target or what we call "Hard Parts" auto parts stores like Pep Boys, Autozone, CSK, Kragen, Reilly's etc.
    You will either have to locate a PBE store in your home town or order online. Most towns have a PBE store they just don't have a HUGE neon sign on their building and usually are located in industrial areas, not on the main drag. To help you locate a PBE store in your home town we have a "How To Article" in our How To Articles forum. (Plenty of more great articles in this forum group).
    How to locate Meguiar's Professional and Detailer products in your hometown
    Here's 3 dressings that can be used on tires that contain no petroleum products. The first one, M40 is the only one available in a 16 ounce spray bottle. The rest are for the Professional Detailing industry and as such come in bulk sizes and must be transfered to a secondary spray bottle in order to use.
    M4016 Vinyl & Rubber Cleaner/Conditioner (16 ounce spray bottle)
    Vinyl & Rubber Cleaner/Conditioner is a complex formula that cleans, penetrates and rejuvenates vinyl and rubber surfaces. Durable protection that screens out damaging UV rays. Restores life and color. Leaves a rich, natural sheen, unlike the shiny synthetic coating of simple protectants.
    M4001 Vinyl & Rubber Cleaner/Conditioner (1-Gallon Jug)
    D17001 HyperDressing
    Until now, the industry average for diluting water based dressings has been one to one or ready-to-use. Meguiar's® Hyper-Dressing dilutes up to four to one, varying the gloss from high to satin. One product, multiple uses...a winning combination for every professional and an industry first.
    D17101 Water Based Dressing - (No Link - Available only through select distributors)
    This water based all purpose dressing restores shine and luster to vinyl, plastic, leather and rubber surfaces. May be used on both exterior and interior surfaces including engines. Spray and wipe at full strength for high gloss application or dilute 1:1 for a natural low gloss look.
    Note that most of our bulk products have matching OSHA approved secondary bottles and spray heads available.
    D20170 Hyper Dressing Bottle - OSHA Compliant - (sprayers sold separately)
    If you opt for a one-gallon jug of M40 then you can pour this off into a generic spray bottle like this one which is also available from Meguiar's.
    D110516 Standard Sprayer
    Economical sprayer yields a fine mist and is ideal for glass cleaner, mist and wipe products, and water based dressings.
    D110542 Chemical Resistant Sprayer
    Resistant to aggressive solvents and chemicals which typically shorten the life of a standard sprayer.
    This is a generic spray bottle and it works great for M40 if you purchase by the gallon.
    M9911 Mirror Glaze Spray Bottle With Sprayer
    Multi-purpose spray bottle with trigger sprayer.
    If you decide to go with a gallon of HyperDressing then these squirt bottles work pretty good to pour-off into; then you simply squirt some product onto an applicator pad and then apply to tires.
    M9912 Mirror Glaze Dispenser Bottles with Dispenser Cap
    Multi-purpose dispenser bottle with cap.
    There's your options if you decide to go with Meguiar's!
    Registered Member Poki's Avatar
    Jul 2008
    U.S.A.
    547
    19
    RV tires tend to have a situation that most cars do not...the rig sits for months or even years at a time without moving it. It is the flexing and heat created from driving that helps the chemicals in tires to work their way out. Using a proper protectant can be a real tire saver.
    Barry
    57
    24,796
    517
    Of the three products listed, the M40 offers both good cleaning and good conditioning/protecting. This would be my choice for the criteria you listed because you want the cleaning action to remove any dirt and dust on the tires but also the brown residue too.
    Just to note, "Car guys in the know" have been using M40 for over 25 years. It's our version of an Armor-All type product only with Meguiar's quality and reputation behind it. Most people that switch to M40 as their dressing for tires, vinyl and other rubber components love it. M40 has a very long and strong base of loyal fans and that's a sign of satisfied customers.
    Hyper Dressing is a great water-based dressing and a personal favorite of mine as long as the surface being treated and maintained is pre-cleaned if needed before applying HD.
    Are these tires brand new?
    Does your RV see a lot of use or is it parked a lot?
    Registered Member AeroCleanse's Avatar
    Dec 2007
    Neenah, WI
    1,116
    22
    When you not driving the RV most RVers put a cover over the wheels to stop the sunlight getting to them. I'm not sure if those are commercial products or just plywood cut outs.
    AeroCleanse, LLC
    www.aerocleanse.com
    Jun 2009
    Hesperus, CO
    4
    9
    Thanks for all your help. We live at 7400' so the tires are exposed to high UV rays. When not in use the tires are usually covered with RV tire covers, however last winter we stored our rig in AZ and forgot to cover the tires. We are trying now to prevent further damage to the tires.
    Thanks again.
    EPHIOS EPHIOS's Avatar
    Jul 2008
    Las Vegas, Nevada
    800
    18
    Is Meguiar's Natural Shine Protectant, water-based or solvent?
    Jul 2008
    U.S.A.
    547
    19
    Good question. I'd like to know that answer too. I'm betting NOT water based because it does not seem to was off very easily.
    Barry
  1. Tire Dressing Test (Round 2) - 56K warning!
    By gb387 in forum Meguiar's Product Raves
    Last Post: May 29th, 2017, 08:10 PM
  2. A look into the TW (TylorWeaver) Method of applying Tire Dressing ;)
    By tylorweaver in forum Tricks of the Trade!
    Last Post: May 29th, 2009, 04:49 PM
  3. PURE Detail: 2005 Silverstone S2000
    By tylorweaver in forum Show Off Your Latest Detail Work
    Last Post: Apr 28th, 2009, 04:56 PM
  4. How to clean a tire protectant applicator
    By 03mach1 in forum Detailing 101
    Last Post: May 1st, 2007, 06:02 AM
  5. NXT Tire Cleaner G-12515 ~ Review ~ Update
    By gb387 in forum Consumer Line - Product Reviews
    Last Post: May 5th, 2005, 07:01 PM
