Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: The Dual Action Counterweight 'Controversy'
  1. #21
    Registered Member inthedetails's Avatar
    Aug 2005
    232
    Let me put it another way, what size counterweight I have on my personal G100 is the least of my worries when it comes to working on anyone's car.
    How's that? [/B]
    Well size doesn't matter anyway, right guys.
  2. #22
    Jun 2005
    613
    14
    The PC repair people I've spoken with said there were no changes made to the machines actually related to detailing and that the "polisher" thing is really about polishing metal (which is what construction guys I know use them for, very different from detailing). They claimed that the counterweights were designed to compliment either 5" or 6" sanding systems, that is, the different weights of the respective backing plates. Do they know what they're talking about? I dunno.
    Note that any foam pad, especially when saturated with product, is gonna weigh a lot more than a single sheet of sandpaper.
    Note also that detailing is about the only application for this tool where somebody will put pressure on it as opposed to letting the product do all the work.
    I find subtle differences between the two counterweights at speed 6 and I use the larger counterweight with all sizes of pads (even 4" ones). FWIW, I find the machine bogs down less readily with the lightest combination of backing plate and pad and IMO we're close to overloading it's design when we use big pads on the thing- hence the "jiggle machine" reputation. It sure doesn't jiggle when you use it as a sander but then people don't apply any pressure to it then either.
    Practical Perfectionist
  3. #23
    52
    24,964
    514
    Re: The Dual Action Counterweight 'Controversy'
    Quote Originally Posted by Accumulator View Post
    Great points to bring out.
  4. #24
    Registered Member hammer55's Avatar
    Dec 2005
    57
    142
    9
    Thumbs up Re: The Dual Action Counterweight 'Controversy'
    thanks everyone for sharing on this, and everything else for that matter
  5. #25
    Aug 2006
    Nashville, TN
    66
    7
    Old thread, but I was cleaning my car up a few weeks ago, and with the PC on 5, my right hand was going numb. I hold the back of the buffer with my right hand, and apply pressure with the left. After working on a section, I would put the buffer down, and my hand would tingle. I was swapping pads, and I saw I had the 5" counter weight on the buffer, so I put the 6" on. Using the same pads (8006), and same technique, my right hand didn't go numb. With the buffer on a lower setting like 2 or 3, I didn't have this problem with the 5" weight. With the 5" weight, the buffer wanted to "walk" across the panel, and it was hard to control that.
  6. #26
    52
    24,964
    514
    Quote Originally Posted by eric96ser View Post
    Were the pads equally saturated or not saturated with product?
    Every time to test or compare and different items, you have to have controls and reduce variables to the 9th degree or your results will be skewed.
  7. #27
    Aug 2006
    Nashville, TN
    66
    7
    I don't remember them being saturated with product. I think I had worked on 1 panel 2 times, and I use a cross pattern when putting the product on the pad.
  8. #28
    Registered Member andyo's Avatar
    Jan 2008
    mount prospect, il
    37
    53
    6
    same with me my hand turns red and feels like pins and needles. i put the speed on 5.0 and it is better but still red hand and no pain. though i only did my car once so far, so i might have to get used to the pc.
    i have no walking and have the pad centered. maby i am doing something else wrong? first time painting and buffing my car.
    1984 buick grand national 1987 engine
    1989 gmc s15 jimmy 4x4 winter beater
  9. #29
    Jun 2011
    Louisiana
    79
    Counterweight only comes in to play when using the DA as a sander.
    You can use any size backing plate and pad with the 5 inch CW.
  1. Replies: 0
    Last Post: Dec 21st, 2007, 12:41 PM
  2. Action of the Dual Action: Slip Clutch?
    By Monk in forum Detailing 101
    Last Post: Mar 22nd, 2006, 05:30 AM
  3. Dual Action Polisher
    By barney 1947 in forum The Dual Action Polisher
    Last Post: Feb 7th, 2006, 02:44 PM
  4. Dual Action Sander
    By Bill Prentice in forum Detailing 101
    Last Post: Dec 19th, 2004, 09:54 AM
  5. Replies: 3
    Last Post: Nov 19th, 2004, 01:03 PM
