i was working my hood today (2004 VW R32) and was surprised that 205 did not remove much of the swirls in my paint.
the problem is most likely the user but i'm wondering if i should be using a more aggressive pad on my porter-cable?
i was using the meguire's soft foam 2.0 pad. should i be using a more aggressive pad with more cut, like a white foam pad?
i clayed the hood first, then worked the polish in until it was lightly hazed (i passed a 2'x2' area roughly 4-5 times, up/down, left/right) with my port-cable at speed 4 with decent pressure.
i then hit it with 7 on a non-cut pad then finished off with 21. it looks marginally better but not what i was expecting.
here are the images of the paint after hitting it with some 205. notice the swirls where the sun reflects in the pant.
should i step up the cut in my pad or my polish?
make it go away!
thanks!
- j
make it go away!
thanks!
- j
