I've used the polsihing pad and the finishing pad before to apply the nxt with the g-100 at 3.5-4.0 but it always seems when i take the pad off there is tons of procuct stuck in the pad still and then built up on the backing plate, i even tried to make sure the last time i used it that i used less but still the same problem, i do not have this problem with any other meguiars products i use with the g-100. any help would be great.. cause i end up throwing the pads out earlier than i should.
thanks,
Jon
thanks,
Jon
