Read this in a post by meguiars actually. (Mike Philips)..Is this true? My main fear was that I would indeed burn the paint. Thx!!!!
G-100 Can't burn the paint?!?!
Re: G-100 Can't burn the paint?!?!
Originally posted by z400
Read this in a post by Meguiar's actually. (Mike Philips)..Is this true? My main fear was that I would indeed burn the paint. Thx!!!!
That's not to say you can't go through paint with the polisher, because you can do this even with your little old hands if the paint is very thin. That's the key here, thin paint.
If you're working on a new car, or a car that has been well taken care of and another owner before you or a detailer or body shop technician hasn't compound the car excessively, then you should be okay. If your working on a factory finish that is still intact, that is it hasn't' been over buffed then it's going to be pretty hard to hurt it with the G-100 and the most aggressive product we recommend with is the W-8006 polishing pad and the #83 DACP.
That said, I've worked on some thin paints before that I wouldn't use any kind of machine on as I could tell that the paint was thin.
Common sense and knowing a little bit about the history of your car's finish will go a long way to preventing any mistakes.
Mike
Originally posted by scrub
Hi there,
I had the same reservations about the PC as you. After using one all summer I'd say it's highly unlikely to burn paint. Not impossible but highly unlikely. I still am cautious around edges, corners and the like.
Paint is generally the thinnest on edges, high points, body lines and seams, etc. Avoid these area, buff up to them, but not on them, or tape them off.
Mike
