Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Pictures & Comments for Advanced Class #5
  1. #11
    Director of Training Mike Pennington's Avatar
    Join Date
    Jan 2004
    Posts
    1,669
    Rep Power
    28
    Re: Advanced Class #5 - 3.21.09
    Quote Originally Posted by termigator69 View Post
    Does the rule of not wetsanding factory paints apply to single stage paints also?
    On vehicles with factory paint you are still dealing with approximately the same topcoat thickness even with a single stage style of coating.
    So it is a good rule of thumb to follow the same general rules....
    Just a reminder: When we say it is not a good idea to sand, we are saying it is not a good idea to sand for the purposes of removing orange peel....However, sanding with the appropriate grit in order to remove an isolated defect would be ok regardless of finish on a factory car as long as you are monitoring the amount of material you are removing.
    Mike Pennington
    Director of Training and Consumer Relations
    Meguiar's, Inc.
    800-854-8073
    mpennington@meguiars.com
  2. #12
    Swirls+Surly=Swurly ClearlyCoated's Avatar
    Join Date
    Jan 2009
    Location
    San Diego, CA
    Posts
    2,153
    Rep Power
    52
    Quote Originally Posted by Mike Pennington View Post
    3) We limit how much sanding is done and with what grit we allow class members to use. We only remove .2 - .4 mils which is well within the specs of OEM factory repair.
    Even did the before and after with the QuaNix meter. Only removed about .2 mil overall if I remember correctly.
  3. #13
    Administrator Michael Stoops's Avatar
    Join Date
    Oct 2004
    Location
    Trabuco Canyon, CA
    Posts
    15,666
    Rep Power
    1073
    Hold on tight, there's a ton of pictures in this post!!!
    This is what we started with -
    Mike Pennington added a little more to the existing mess.....
    A little wet sanding by hand........
    Wet sanding by hand the right way.....
    .....and the wrong way.
    Wet sanding with a D/A.....
    Very nice!!
    Cleaning the wool pad.......
    How to pick up a bead of product.....
    Pulling out sanding marks......
    Oh come on, he didn't actually miss a spot, did he???
    Ah... no. Mike's a bit picky, eh?
    And then we turned everybody loose on the rental car!!
    (800) 854-8073 xt 3875
    mstoops@meguiars.com
    Please post technical questions directly to the forum rather than emailing or PM-ing me. You
    will get a faster response on the forum, and your question could help someone else, too!
Thread Information
Users Browsing this Thread
Similar Threads
  1. Advanced Class #2 - Pictures & Comments
    By Mike Phillips in forum Pictures from our Advanced Classes
    Last Post: May 28th, 2008, 02:12 PM
  2. Advanced Class #1 - Pictures & Comments
    Last Post: Apr 19th, 2008, 06:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
