Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
Thread: Tips for removing swirls by hand with SMA Technology
    Jan 2009
    New Lenox, Illinois
    10,180
    292
    Hello everyone,
    Over the last two days i have been doing a full swirl removal on my truck with my 2 hands, 5 foam applicator pads, SwirlX , Scratch X 2.0, and Ultimate Compound. I am all done with the exterior and just finished cleaning up all my supplies in the garage from my weekend project. It is NOT impossible to remove swirls by hand. I used artificial lighting and the sun as my guide to see if i was actually removing swirls. Both my arms are about to fall off and tomorrow is the interior which is nowhere near as hard as what i have been doing the last two days.
    Ultimate Compound Tips
    - First off, this is an actual Compound and just because its in the consumer line doesn't mean its not aggressive
    - do a test spot first , see if it finishes LSP ready and go from there
    - I found that when i did a whole panel with UC that it was too aggressive and i didn't need that strong of a product to apply to the whole truck. I think there would have been a lot of marring if i did.
    - work small areas , i would say if your trying to remove swirls then a size of a microfiber would be about right.
    - do not try and work too big of areas, if you do then odds are you wont work the product in long enough or remove any swirls and possibly create more problems
    - use a yellow foam applicator pad, i find there better than the blue ones for defect/swirl removal
    Swirl X Tips: This is the product i chose to apply to the entire truck and even applied it twice on some panels. It took 2 days just to do the whole truck with Swirl X because i wanted those light swirls i had in my truck gone. I took my time and i got a swirl free finish
    - don't overuse product, a little goes a long way in a small area.
    - clean your foam wax pad often
    - if you don't clean your foam wax pad often then simply grab another one
    - this product is just right for removing swirls and i think is the most effective for that specific problem
    I didn't experience any marring when i viewed the truck in the sunlight
    - if your hand gets tired, then go back and forth between both your hands.
    General tips for working by hand
    - dedicate a whole weekend, or predict how long it will take, take into account size of car and severity of swirls.
    - don't give up, if you work small areas and work the product in properly then you will remove at least some swirls, keep in mind SwirlX is more aggressive than M83!
    - take advantage of the SMAT technology and understand how they are different than diminishing abrasives
    - sometimes it takes more than one pass
    - if one hand gets tired then switch to the other.
    - take a break after every panel or so and get something to eat or drink. I found that closing my eyes relaxed me
    - take your time
    - if you rush then your results wont be as good as you expect them to be
    - use the sun, artificial lighting doesn't show everything
    - if your car is small enough then it may not take as long as it does for larger vehicles.
    - evaluate how bad your swirls are. In my case they were mild.
    My Personal Experience:
    Keep in mind this is just my personal experience on a Chevy Silverado, these 3 new swirl and scratch removers wont perform the exact same way on every single car. So for example: UC may finish LSP ready and it may not, for me it didn't, which is okay. So what did work for me for me was SwirlX. If i would have been in a big hurry and used UC on the whole truck and used it improperly, well things wouldn't have went okay. But having more than one product at your disposal always helps and in my case was kinda a lifesaver.
    hopefully this will help others as well and be sure to keep in mind this is just my personal experience and not any official answer from Meguiar's
    Thanks for reading
    Jan 2009
    New Lenox, Illinois
    10,180
    292
    Re: Tips for removing swirls by hand with SMAT Technology
    this thread will get pics momentarily
    Jan 2009
    New Lenox, Illinois
    10,180
    292
    nothing to hide:
    Fire Dept. Detailer Carfire's Avatar
    Aug 2008
    Ozaukee County ,Wisconsin
    21
    2,837
    34
    Great Tips Nick!!
    Thanks for Sharing!!
    Truck looks Great!!
    Jan 2009
    New Lenox, Illinois
    10,180
    292
    Quote Originally Posted by Carfire View Post
    Great Tips Nick!!
    Truck looks Great!!
    Im just glad its finally swirl free
    thanks for all the help and kind comments ive gotten from you since ive been here
    Aug 2006
    Yreka, CA
    3,533
    180
    Tuck, great write up and follow up photos showing your results AND telling us your experience to boot
    The truck looks awesome.
    It's nice to see writeups on the consumer line of products as well as the Mirror Glaze/Detailer lines. I don't know how many of us started on the Deep Crystal 3 step process and migrated to the professional products as time goes on.....or simply stayed with what works.
    Kind of like: Find something you like and use it often eh?
    We finally have the new '09 UC, UQW, SwirlX in our area and waiting for better weather to try some.
    Good Show
    Edit: I'm sure this may find it's way into Hot Topics!
    Jan 2009
    New Lenox, Illinois
    10,180
    292
    Quote Originally Posted by Nappers View Post
    Good Show
    Thanks for the kind comments Nappers,
    I think these new products are fantastic and like you said the Deep Crystal 3 step series are great stepping stones. My trucks paint isnt real hard and it isnt real soft so SwirlX is my new favorite product. After all it made my truck swirl free finally. I bet you cannot wait to use them on your Yukon and then im sure your Neon is next. So in the end i got my truck swirl free and got a two day workout!
    I hope when the weather warms up you will have the same great experience i am having with these new products
    take care
    52
    24,964
    514
    Excellent write-up... good tips and information for those new to working by hand.
    We're going to make ths a Sticky.
    Hobby Detailer MyFirstES300's Avatar
    Feb 2009
    Orange County, NY
    41
    560
    Re: Tips for removing swirls by hand with SMA Technology
    This indeed is a great write up. I have a lot of buffer swirls on my finish that was left behind by the dealership when they detailed the car. My guess is they were in a hurry (this was a dealer prep, I didn't pay for it. This is the condition I got it in when I bought it).
    Otherwise, the paint is great! I think using your techniques and a lot of patience, I can get a swirl free finish.
    Registered Member 10degreesbtdc's Avatar
    Mar 2009
    Clearwater, Florida
    328
    Thanks Tuck! I couldn't have read this at a more appropriate time as this Jeep has a lot of areas that must be done by hand. A small spot, compound, polish, several passes on each usually.
    Great looking work!
  1. How To Remove Swirls By Hand
    By Mike Phillips in forum How-To Articles
    Last Post: Aug 16th, 2012, 06:20 PM
  2. Replies: 5
    Last Post: Feb 24th, 2009, 09:17 AM
  3. Using ColorX by hand, for the first time, tips please!
    By Raymond in forum Working by Hand
    Last Post: Aug 26th, 2008, 09:11 PM
  4. Tried to remove swirls by hand...
    By EV0B0Y691 in forum Detailing 101
    Last Post: Mar 13th, 2007, 08:33 PM
  5. Removing Swirls by hand
    By manueljlg in forum Detailing 101
    Last Post: Apr 4th, 2004, 02:46 PM
