I have used Meguiar's Deep Crystal Step1 Paint Cleaner and Step 2 Paint Polish in the past. After doing some research here on the forums, I wonder if I have been getting the most out of the products. I know that I should not allow either the cleaner or polish to dry on the surface.
First, for the Paint Cleaner:
1. How large of a section should I work at one time? Usually I work the roof as one section, the hood as another, each door, etc. as a section. Should I break up those into even smaller sections? Such as breaking up the hood into 4 areas?
2. How much does this product need to be worked into the paint. Do I pass over each section once or twice, or continually work the product into the paint in different directions? How do I know when to stop working the cleaner into a given section?
On the Paint Polish:
1. Would the same rules of sectioning the car apply to this step as well?
2. Does this need to be worked into the paint in the same way as the cleaner or is this more of a wipe on and wipe off?
Materials:
I usually use either 100% terry cloth towels or MF towels purchased at the local auto parts store (Usually Advance Auto). Are these towels of sufficient quality or should I be looking somewhere else for towels.
Any guidance is appreciated. Thanks.
Materials:
