Freshly washed, spray the booster wax on while it's still wet and use a microfiber to dry? Think the label said you could do this. Any one done this yet?
Anybody use NXT booster wax on a wet car?
I do this quite often, but don't be fooled you will have to dry the car twice if you use the booster wax. I actually prefer the Eagle 1 Wet as U Dry since it wipes off when you dry the car and does not need a 2nd wipe....the NXT does work well."Washing for the People"
I have tried that and I prefer to use the SBW on a dry surface. You can use it on a wet surface but I see no advantage in doing so. It takes longer for it to dry and if you don't wait long enough it is difficult to remove.
I have never used Wax as U Dry but I think it is designed to be removed while it is still wet.
RamAirV12015 Dodge Charger R/T Scat Pack 392Granite Crystal
2006 GTO Impulse Blue
