Results 1 to 10 of 17
Thread: How to clean microfiber towels
    Nov 2008
    NM
    43
    How do you clean a well used microfiber towel so it's clean for next use?
    Thanks.
    Avatar Czar Ryan L.'s Avatar
    Aug 2006
    San Diego, California
    26
    2,678
    47
    Re: How to clean microfiber towels
    Wash the towel with your other microfiber towels on HOT.
    No fabric softener.
    Dry on normal, or fluff or air dry.
    Ryan
    Registered Member Lexus Guy04's Avatar
    Oct 2008
    Nashville Tennessee
    32
    471
    14
    There are SEVERAL threads on this topic that have a lot of useful information including specific techniques a lot of us have found work best. Just do a search.
    '05 Arctic Blue Pearl Acura TSX
    '03 Silver Lexus RX 300
    Jun 2005
    The Real NorCal
    4,102
    142
    Basically:
    1. Wash hot, detergent APC mix.
    2. Dry with heat.
    3. Fold.
    4. Enjoy.
    Tips for washing:
    If you have the washer set to a full load water level (what I always use as it really isn't that much more water and usually measurements are based on a full load anyways so it makes it easier), use about a 1/2 detergent lid/cup full of detergent and about a cup of APC. I give the APC a 1, 2, 3 pour. I use the 1/2 gallon Simple Green bottles for this. After the initial washing, keep running rinse cycles until there is no soap at the top and on that rinse cycle, add a cup of white vinegar. Once you get the mix of detergent down, you should only need one, maybe two rinse cycles. Use too much and you may be running many, many rinse cycles. Go from there. No fabric softener or bleach.
    Tips for drying:
    No drier sheets (i.e.- just dry the towels with no drier additives).
    Jun 2005
    The Real NorCal
    4,102
    142
    I think from now on, I'm just quoting my above post, lol.
    大家好 Late Bloomer Bunky's Avatar
    Apr 2007
    Raleigh, NC
    445
    15
    Quote Originally Posted by roushstage2 View Post
    As Lexus Guy 04 says, there are a lot of good posts on how to clean microfiber. Your technique would not work with a front loader since the machine controls the water used. If you have hard water, you may have to add a bit more detergent but usually less is better and just do a pre-soak (like spray spots with APC) and wash longer.
    I have used Tide and Woolite but I did get some dedicate mf cleaner in trade and it seemed to work too (just 2 oz for 1/2 load). In my experience, if you need vinegar you are probably using too much detergent. I just get by with a second rinse.
    Al
    ~ Providing biased opinions
    Fire Dept. Detailer Carfire's Avatar
    Aug 2008
    Ozaukee County ,Wisconsin
    25
    2,837
    39
    I do not wash mine on hot, because then the colors bleed. Otherwise I just put them in and add detergent and no fabric softener.
    Detailing Dunce akimel's Avatar
    May 2008
    Roanoke, Virginia
    2,378
    147
    A fellow MOL member, dftowel (Leo), who seems to know a lot about microfiber towels, recommends the following:
    "Proper care is simple:
    Wash after every use as soon as possible, don't let them sit for a week or two.
    Use HOT water
    Use liquid detergent, I recommend ERA
    No bleach or fabric softeners
    HOT dryer, no softener sheets (your towels will not melt)"
    After reading Leo's instructions, I have begun to use hot water fearlessly. The rationale is that hot water is necessary to effectively clean the towels of grease, wax, and silicone.
    However, I still dry my towels in the drier on "delicate" setting.
    --Al Kimel
    Jun 2005
    The Real NorCal
    4,102
    142
    Quote Originally Posted by Bunky View Post
    I'm aware. I have posted in a lot of those threads. I guess I'm confused a bit on the front loader thing, as all machines control the amount of water used based on what size load you are selecting? If you have hard water (which I do where I wash all of my towels), I wouldn't use more. The hard water makes it a PITA to wash the detergent out. The APC rinses out much more easily than the detergent which is why you'd want to use less detergent and replace it with APC.
    The point of the vinegar is to remove any remaining soap residue. I use it more as a just because since it is so cheap and just to make sure all of the soap is gone. That is why you have to keep rinsing until there isn't any soap at the top and don't overuse the detergent (another reason I say to use less).
    Detailing BoZo jfelbab's Avatar
    Apr 2004
    Cape Coral, FL
    1,462
    28
    I use Tide HE at 1/4 strength in my Maytag front loader.
    The nice thing about adding vinegar to the rinse cycle is that it acts as a natural fabric softener and yet doesn't reduce the absorbency of the towel like a fabric softener will.
  1. microfiber towels
    By paradog in forum Detailing 101
    Last Post: Oct 8th, 2006, 09:12 AM
  2. Microfiber towels
    By DCRANER in forum Detailing 101
    Last Post: Jul 25th, 2006, 12:44 PM
  3. Microfiber Towels...
    By kvuong in forum Detailing 101
    Last Post: Jul 19th, 2005, 11:50 AM
  4. Microfiber towels
    By JG_Detailing in forum Detailing 101
    Last Post: Jul 7th, 2004, 04:48 AM
  5. Microfiber towels
    By geoff in forum New Product Suggestions
    Last Post: May 9th, 2004, 09:28 PM
