SoftBuff pads - how clean is clean?
  • SoftBuff pads - how clean is clean?
    Recently I used a couple SoftBuff 2.0 pads to clean (ScratchX) and wax (NXT Tech Wax 2.0) a car. The pads were brand new so obviously they got dirty. I washed the ScratchX pad in the washing machine but even after that, it is still dark and has "ripples" in the center. It also smells HEAVILY like ScratchX. Is this good to go or should I do something else to really clean it thoroughly? I just don't want it to instill swirls in the next car that I do because it's going to be a black car. Thanks.
    -HealthyCivic
    Check out the glossary
    Re: SoftBuff pads - how clean is clean?
    After washing it in the washing machine it's clean enough to use again.
    You're never going to get your pads to look brand new again after having used them and then washed them.
    Don't make things more complicated then they need to be. Use you pads, wash and dry them when you're finished with them, store them in a clean, dry place till you're ready to use them again.
      Thanks Mike!
      -HealthyCivic
        I've ran across the same thing myself. One thing I found that helps is to aggitate it with a brush before you stick it in the wash, or blow it out with some compressed air. Mainly you're just getting the big stuff out of the pad by doing this, then toss it in the wash and it looks a ton better. Not perfect but better.
        2008 Meguiar's Batmobile Team
        2008 Meguiar's/Ford SEMA Team
        2009 Meguiar's/Ford SEMA Team
        2010 Meguiar's/Ford SEMA Team
          For that matter, you can hold the pad under running water and with some soap squish the pad with your hands and this will act to work the soap into the pad and act to work the soap and product residue out of the pad.
          Last time I checked, my washing machine doesn't have hands that come out during the wash cycle and do this squishing action.
          Again, you can make the cleaning process as simple or complicated as you like, that's up to you and your expectations for how clean you want your pads and everything else you want to clean.
            On all of my Foam Applicator pads I run them under very hot water in the sink and squish them out and use Tide Detergent and rub it in by hand over and over. It makes them look good. The washing machine messes up my Microfiber Applicators.
            Matt
              Thanks for the tip,Nick.
                Looks like it is time for an upgrade!
                  Man Mike, when I bought my new Maytag a few months back, it specifically said that Mike Phillips hands will come out during the wash cycle and squeeze all of the excess product from my 2.0 pads.
                  '05 Arctic Blue Pearl Acura TSX
                  '03 Silver Lexus RX 300
                    This is what I do, each time it works great
