Polish clear coat
  • Polish clear coat
    I was sanding a paint chip with 1500 grit sandpaper than I used 2000 grit sandpaper.I created a slight dip in the clear coat that if seen on a angle you would think there is a dent/ding.I'm not keen on using the sand paper again.Would it be best to use polish and in time the clear coat would even out?Any info would be great.Thanks Joe
    Re: Polish clear coat
    I'll rephrase.The clear coat has a slight valley.I was trying to sand a paint blob and instead of placing the sanding block flat on the surface I used the edge of the sanding block.I'm between using using the sanding paper(1500-2000 grit) or scratch remover.Thanks Joe
      If you have managed to sand a valley into the clear coat then I reckon you are stuck with it unless you get the entire area re-sprayed! In this case it is easy to takeaway but not so easy to add!
      Depending of the thickness of the clear coat someone with a lot of experience may be able to sand it a bit more to make it less obvious - they would need to know what they are doing though!
      BTW: I would reckon you would get better attention if you post this thread into the correct forum
        I moved this over to Wet-Sanding, Color Sanding, Rock Chip Repair for you as that is where questions of this type belong. When in doubt, post them here in the future for the best chance at getting quick replies.
        Thanks!
          What is it you're working on?
          One of the things we teach on this forum is that factory finishes are thin, there's not much film-build to work with and this makes sanding on factory finishes risky.
          Everyone reading this into the future needs to learn from his mistake and deeply consider the risk involved before sanding on a factory finish.
          Too late for that, best thing to do at this point is to carefully remove your sanding marks and cross your fingers that you don't go through the clear coat and expose the basecoat and then live with the results unless you want to have the affected area or panel repainted.
          It might be possible for an experienced Pro to sand the area surrounding this low area and then remove all the sanding marks but this too would pose some level of risk and would be best done by machine using a hard backing plate with a high grit paper, something like the 3M Trizact System.
          Hope this helps...
