W9207 - Washable Foam Finishing Pad
  • #16
    Re: W9207 - Washable Foam Finishing Pad
    Originally posted by Mike Pennington View Post
    In combination with our new backing plates, you see even better results !
    Mike
    So is the new DA backing plate slightly larger in diameter than the old one then?
    Brian
    • #17
      Originally posted by Infinitevisi0n View Post
      ^^not sure on how that specifically answered my question
      No would be the simple answer to the original question of "wouldn't the 7 pad be a little big?"
      How do you wash these?
      You would wash them separately in a normal washer with other pads, using a regular washer detergent. When drying, we recommend using a low heat setting.
      Mike
      Mike Pennington
      Meguiar's, Inc.
      800-854-8073
      mpennington@meguiars.com
      • #18
        SoftBuff™ 2.0 Polishing Pad
        Item # W8207
        Is this washable too? I would rather get this one if so but it doesnt say whether its washable. Plus arent Meguiars losing business by having a washable pad? lol just askin
        • #19
          SoftBuffâ„¢ 2.0 Polishing Pad
          Item # W8207
          Yes all Meguiars 2.0 pads are washable including the polishing pad. IMO this is an excellent path for Meguiars to take. I have had great success with Meguiars Softbuff pads and have been waiting for a machine washable pad for some time now. My old pads I washed by hand and that can get time consuming as many others who do the same know. By making a washable pad... IMO you are giving more opportunities to use more Meguiars products. Some say I don't want to buy another polish/wax/cleaner as that means I need another pad, well now you can mix and match any product and use the same pad... just my $.02
          Brandon
          2007 Black Chevy Avalanche
          My Albums: Avalanche
          • #20
            Item # W8207
            Depends how you look at it. On one hand, they are offering a superior product that people will be more likely to keep clean and re-usable for longer which may in turn reduce the need for replacement pads. On the other hand, it is a superior and one-of-a-kind (to the best of my knowledge) product that will hold extra interest to new buyers.
            I know I stocked up and stopped wasting my time trying out other brands when the 2.0 came out because I would rather use these pads exclusively where possible since it makes my life easier. Easy = Good
            • #21
              when do you use the cutting pad?
              • #22
                Heavy defects... possibly for taking our DEEP etching, or removing sanding marks with a rotary and M105. Some people prefer a foam pad to wool, so the cutting pad is good for that application.
                • #23
                  is there a discount code i should know about before i purchase these?
                  • #24
                    The last discount code has expired and at this time there is no new discount code.
                    • #25
                      This will also provide a good backing for a bonnet used to remove wax, that said I am not sure there are any out yet that will fit this new size of pad.
                      Brandon
                      • #26
                        so do you work for the company mike? lol cause I think I discovered something but cant say just yet
                        • #27
                          Yes I work for the company.
                          Started here at the Corporate office in 2002 as Corporate Write transition to Admin on the forum and class instructor in 2004
                          1999/2000 Oregon Distributor Professional Detailer Line
                          1988 to 1989 Outside Sales Rep & Trainer for Oregon, Washington and Northern Idaho
                          • #28
                            I know this is very old thread..but i have a question
                            How aggresive is to use rotary with W9207 and 205 ( little bit more amount then normal) and with little pressure. It was 4-5 passes between 1200 and 1500 rpm with moving cca 3-5 centimeters pro second. Car is bmw e93 mineral white.
                            Is it possible to remove after each polishing with this combo more than 3-4 microns ?
                            I have measured yesterday paint thickness and on some spots( doors, trunk) on the lowest level (just above side skirts) it less then 95..and as i go above paint is thicker, max is 133 microns on engine hood.
                            The question, how much is this aggresive? Is is possible to remove more then 3 microns with that? The paint is like mirror but dont know is my clearcoat now too thin and with less shine then it could have..
                            I have polished it with this combo 4 times in 2.5 year since i bought it..
                            • #29
                              nothing? :/
