how do i remove wet sanding marks from use of traditional wet sand paper
Results 1 to 10 of 16
Thread: how do i remove wet sanding marks from use of traditional wet sand paper
    professional detailer bigjoes's Avatar
    Oct 2008
    kitchener ONTARIO
    38
    23
    i went a little deep and ive buffed the surface and its pretty good but not perfect i was going to try to use meguiars wet sand paper because of the unigrit tech to see if i can remove the light scratches left behind from the crappy wet sand paper
    will this fix the prob or should i just work the surface some more with the buffer and wool pad followed up with a polishing pad and then a finishing pad
    Pro/Marine/RV Product Manager Mark Kleis's Avatar
    Jul 2006
    Orange County, CA
    33
    4,135
    143
    Re: how do i remove wet sanding marks from use of traditional wet sand paper
    I'm moving this to Detailing 101 as this is where it belongs. "New to Discussion Forums" is for questions about how to use the forum/website, NOT for detailing questions.
    Mark
    Registered Member yalerd's Avatar
    Jan 2006
    4,439
    119
    What grit did you use? Are you removing the sanding marks with a rotary buffer?
    Finishing with a high grit sand paper will make it easier to remove with a rotary buffer.
    57
    24,779
    517
    Is this a "Daily Driver" or a Show Car?
    Is this the "Factory Finish"?
    What was the original purpose of sanding the paint.
    Factory paint is thin and hard, the MAJORITY of all wet-sanding is done in a body shop situation where extra paint is sprayed onto the car just for the purpose of having more material to work with by the person doing the sanding and buffing. Also, the car is sanded and buffed while the paint is still soft and easy to buff sanding marks out of.
    Too many people reading about wet-sanding on "other" forums where they don't include the above paragraph and then these other forums give everyone reading them the idea they can simply sand down their car's paint and quickly and easily buff out the sanding marks and this isn't reality.
    The safest thing to do is to NOT sand down factory paint on daily drivers. That said, if you've already done this then in most cases it's safer to re-sand with a higher quality paper and a higher grit and then CAREFULLY remove your sanding marks with a high quality compound like our M105, not some compound that's in the same league of the papers you've already used.
    Best of luck...
    Oct 2008
    kitchener ONTARIO
    38
    23
    it is a daliy driver when i bought the car someone had put spray paint over the clear coat so i wet sanded that off of the paint and i one spot put so sanding marks in that didnt come out totaly
    i just talked to my meguiars rep and he sugested using solo cut and polish so not to go to aggressive and using the red and white wool pad and a polishing pad and only if that dosent work to use unigrt sanding paper and that he would show me the proper way to do that
    have i said i love megs
    Oct 2008
    kitchener ONTARIO
    38
    23
    Thumbs up Re: how do i remove wet sanding marks from use of traditional wet sand paper
    Best of luck...
    my meguiars guy is comming in on wed this week he said the same thing you did and that we have to use 2500 - 3000 unigrit sanding paper that
    my mistake was going to canadian tire and buying there wet paper
    im also going to get ultra cut compound and ultra finishing compound
    but i have made it look better already with solo cut and polish system
    i love making it even more shiny and flawless
    thanks
    j stan
    Skoda Club irf@n's Avatar
    Sep 2008
    Istanbul, TR
    44
    136
    M83 can easily remove even the 1500 grit sanding marks on factory paint (VW) using rotary buffer...
    Skoda Roomster
    Oct 2008
    kitchener ONTARIO
    38
    23
    what is that product name
    Registered Member benhui86's Avatar
    Sep 2004
    SF Bay area
    813
    22
    next time you tackle spray paint.... try clay.... even paint thinner is better idea than sand paper because you risk sanding through the clear coat easily if the wrong technique is used.....
    but anyways some people had good luck using 105 to remove even tough sanding marks so you may try that......
    Sep 2008
    Istanbul, TR
    44
    136
    Quote Originally Posted by bigjoes View Post
    Meguiars Mirror Glaze #83 Dual Action Cleaner/Polish
    Skoda Roomster
  1. remove wet sanding marks with ScratchX
    By Leonard1818 in forum Wet-Sanding/Color Sanding Automotive Paint
    Last Post: Jun 27th, 2009, 04:23 AM
  2. Can Ultimate Compound remove wet sand marks?
    By dragonballz in forum Wet-Sanding/Color Sanding Automotive Paint
    Last Post: Feb 12th, 2009, 05:44 PM
  3. Wet Sanding Marks, Be Removed?
    By AJSP in forum Detailing 101
    Last Post: Aug 20th, 2005, 04:03 AM
  4. Perforated Wet sanding Paper
    By Bill D in forum New Product Suggestions
    Last Post: Jun 29th, 2005, 02:01 PM
