I have done body in the past so running a Makita 9227c is not new to me....Using it on a finish is.
working a finish back to good health is a lot slower and patient processes.
What I am Having troubled with is when use #83 on a W-8006 Soft Buff® Foam Polishing Pad,
The pad seems to **** up all the product (not absorb it) it just seems to coagulated in the middle of the pad
and then the 9227 get hard to handle wants to jump up and pitch you can hear the machine loading up(tourque) and then the coagulated #83 will just drop off the pad in a 4" wide by maybe 5" long lump, Thick almost impossible to remove with out spraying QD on the spot.
Different ways I have tired are;
1. prime the pad with QD and then do an X on the pad but this seem to sling allot
2. prime the pad and lay a line on the surface and do a counter clock wise lay over ( Rod Craft tough us this method) it still slung then went in to the build-up stage again as previously mentioned.
I am working a 2'x2' at the most area.
The Makita is 9227c
setting were
2 = 900 rpms
3 = 1,500 rpms
4 = 2,100 rpm with this setting I used the variable trigger and did not allow it to go to full speed but did use it as a throttle when it torqued down under drag.
Note to self:
I should have bitten the bullet when Rod offered us to use the rotary at the detail day in NJ. but though since I had some experience using this type of equipment I'd let some of the others there try it out...Don't think that will happen again.
Thank in Advance
The Makita is 9227c
setting were
2 = 900 rpms
3 = 1,500 rpms
Note to self:
Thank in Advance
