Results 1 to 10 of 15
Thread: Proper terms
    www.marinetoys.ca Marine Toys's Avatar
    Sep 2008
    Vancouver BC
    209
    7
    Proper terms
    What are the proper terms for this photo?
    32
    18,010
    219
    Re: Proper terms
    Sounds resonable... the terms spiderweb/cobweb could be used as well.
    In between your swirl and haze though, there could be some holograms as well.
    52
    24,964
    514
    Re: Proper terms
    The one marked haze looks like normal swirls to me.
    I see "finger marks" in the paint, finger-marks are the small round spots that are hazy, they are caused by the pressure of your fingertips against your applicator pad working some kind of abrasive product, they are usually inflicted when your hand stops in it's motion to reverse directions when rubbing the product.
    52
    24,964
    514
    Re: Proper terms
    From Hot Topics
    Cobweb Swirls vs Rotary Buffer Swirls
    Below is an explanation between the difference between random swirls and scratches that show up in what is commonly referred to as Cobweb Swirls as compared to Rotary Buffer Swirls.
    Cobweb Scratches or Cobweb Swirls
    Actually, the term cobweb swirls or spiderweb swirls comes from the fact that when you look at the paint in such a way as to place the reflection of the sun or another source of bright light so that it's on a painted panel, you'll see what looks like swirls and scratches forming in a circular pattern around the point of light.
    Now if you move around a little bit so as to move the point of light around on the panel you'll see what looks as though the cobweb swirls are following the point of light. The cobweb swirls are not actually following the point of light what's really happening is that the entire finish is so filled with random scratches that wherever you place the point of light you'll see the circular or cobweb pattern show up because the random scratches will reflect the light back towards the center of this point of light. So as you move the point of light around on a painted panel it looks as though the cobweb swirls are following the point of light.
    Does that make sense?
    The scratches are not specifically circle scratches, they could be a all straight-line scratches but the effect is they look circular because the point of light is circular and the light hitting the hundreds of thousands of scratches are all reflecting back to the center of the point of light making it look as though the scratches are all circular when that's not the case.
    Buffer swirls or Buffer Trails or Holograms
    Swirls instilled through the use and mis-use of a rotary buffer will tend to show up in a pattern that reflect the direction the rotary buffer was moved over the surface.
    Rotary Buffer Instilled Swirls
    Hope this helps to explain the difference.
    52
    24,964
    514
    Re: Proper terms
    Possible fingermarks circled
    52
    24,964
    514
    Re: Proper terms
    Something posted about fingermarks here,
    Fingermarks
    Avatar Czar BlueZero's Avatar
    Aug 2006
    Green Bay, WI
    3,312
    42
    Re: Proper terms
    Cool! I just learned something new.
    Never knew what fingermarks where. I've seen them before just never knew what caused them or that they had a name.
    Scott
    52
    24,964
    514
    Re: Proper terms
    Quote Originally Posted by BlueZero View Post
    Somewhere I have an awesome picture of fingermarks, just need to remember to upload it next time I stumble over it looking for images.
    Sep 2008
    Vancouver BC
    209
    7
    Re: Proper terms
    It wasnt my picture but thanks very much for all the info , just trying to get a idea of things to look for when I screw mine up Like i have. But man there is a lot of great info on this forum, It has taken me 3 days to read so far and a lot more to go
    KEEP UP THE GOOD WORK !!!
    Detailing Dunce akimel's Avatar
    May 2008
    Roanoke, Virginia
    2,377
    143
    Re: Proper terms
    What is a hologram? Is one present in any of the above photos? TIA.
    Al
  1. where does #2 fall in terms of aggressiveness
    By benhui86 in forum Professional Line
    Last Post: Aug 16th, 2008, 09:23 PM
  2. Proper way to use search
    By mongo in forum Detailing 101
    Last Post: Oct 25th, 2006, 12:57 PM
  3. Proper Technique
    By RWayne in forum Detailing 101
    Last Post: Jul 5th, 2006, 01:21 PM
  4. First Proper Detail
    By mheaford in forum Show Off Your Latest Detail Work
    Last Post: Mar 26th, 2005, 12:18 PM
  5. What MG product is next after #9 (in terms of Abrasiveness)
    By mattfletcher in forum Detailing 101
    Last Post: Jan 17th, 2005, 08:19 PM
