oops Mixed 120 oz Glass concentrate with 10 oz Wheel Brightener
  • oops Mixed 120 oz Glass concentrate with 10 oz Wheel Brightener
    I had a brain fart and ended up mixing this solution.
    What can i use this mix for? Would it still be safe for windows when i dilute it 10:1, could i use this as a wheel brightener as is, or do i have to scrap the solution?
    Dubble
    Re: oops Mixed 120 oz Glass concentrate with 10 oz Wheel Brightener
    Shouldn't hurt to use it to clean wheels but you don't want to risk getting it on paint or any kind of rubber or plastic trim around the windows, not to mention your eyes or interior components.
      Thanks Mike
        That is a heck of a brain fart
          Maybe you can use it for these wheels...?
            What can i use this mix for? Would it still be safe for windows when i dilute it 10:1, could i use this as a wheel brightener as is, or do i have to scrap the solution?Dubble
            OK, so you miscalculated slightly but before I just poured your mistake down the drain lets take a good look at what you mixed. You basically created a 12:1 solution of glass cleaner and wheel brightener. Since the majority of it is glass cleaner concentrate I would mix 10:1, 10 parts water with 1 part of your concentrate and test this mixture on glass. Use a Microfiber towel and clean your windshield as you normally would and determine whether or not this is an acceptable solution for your oversight....
            BobbyG
