your tire washing method
  • your tire washing method
    one of the main reasons i get on this site is to learn more things and get different ideas.
    I'm just curious what process you guys do/use?
    Re: your tire washing method
    i spray with a rubber cleaner, scrub, rinse and once they're dry i dress them.
      I use a all purpose cleaner or degreaser like All Purpose Cleaner (APC) or Super Degreaser. Spray the product on and scrub for a few minutes, wash off then let dry thoroughly before dressing.
      Ryan
        I use a brush with some car wash soap or a tire cleaner.
          I use dish detergant. I feel that it gets the old dressing off. Never tried Megs product yet. Will do when I place my next order.
            I use APC, a foaming head sprayer, and a soft toothbrush.... Spray, agitate, rinse. Then do the wheels.
              i tried for the first time a pressure washer to clean the wheels. worked pretty well getting the grime and scuff marks off the tires. washed them afterwards w/ meg's soap and water using a sponge.
                I use APC, Meguiars tire brush. Rinse all done.
                  I have been using Eagle One's all wheel and tire cleaner. I like it because I can do the tires and wheels in one shot. It works very well IMO. Can APC be used on wheels also?
                    APC + "tire brush" I purchased from walmart or fred meyer. Its basically a rounded triangle with a concave center. It wraps around nicely and fits in the hand alright. Bristles are fairly rough, and not safe for the wheel itself. I typically follow up with my softer wheel brush (typically soft brush, 1 foot handle) and grab right behind the head holding the bristles with my finger tips (they're to soft for rubber scrubbing with any sort of pressure). Tight fast circles once around polishes the tires off (using soap and water and APC if needed) leaving it ready for more dressing.
                      If I may inquire, what dilution ratio do you use?
                        I use the Meguiar's NXT Wash Soap w/a brush. Then Hot Rims Tire Spray.
                        Matt
                          anyone use wesley's?
                            Been using it since I was a kid. Tried megs Super D and APC+, they didnt come close to being as good as wesleys.
                              I use it at 10:1 right now. I will admit occasionally I have to do the tires twice if I cleaning them after using Endurance tire gel. But otherwise no problems.
