hey everyone, so as i am new to detailing, i am still working out the kinks as you can say.
so, i am pretty sure i am using too much product. but i would like your opinions to make sure. first, i am posting pictures of 85 i used on a car this weekend. this car has major scratches and it took 3 passes to get it somewhat ok, followed up with d151, end result was great... but.
Here is stage one: too much product i know this. but is it worked enough ? it was easier to remove this.
As i worked it just a little more, 20 seconds maybe this is what it looked like... gummy. doh. It's also hard to remove.
Then on another spot i used only a small amount on the pad, maybe 4 dime sized drops. worked it for a bit until it cleared up and was mostly gone.
So, which was the best way to do it , or best combination of tactics.
By the way, am using a flex 3401 and at a speed 5 out of 6.
Next problem... here is what i did to one of my pads after using the flex for about 6 hours straight... i guess it should take a break...
broken pad: too much heat from the polisher, not from the product side. time to order a new one.
Then my flex... it's dirty i know... that is what i get when i used a wet pad and added product and spun it up... splatter all over... .
Anyways, the problem: too much heat from the center of the backing plate: why is that: too much work time, too fast or does it need to be greased, because the manual says nothing about greasing it or generating heat.
See the center of the backing plate has actually melted plastic... also when the above pad was damaged.
So, if you can comment on these for me that would be great to help me make my detailing a little smoother.
