Hi folks!
Since my parent's cars have some deeper defects which I cannot remove with abrasive polishes only, I bought some wet sanding paper.
Yesterday was the day to try it out.
I took the old grille of my father's Astra OPC, as seen here:
I washed and clayed it first to achieve this.
Because there was not even 1 deeper scratch I decided to create some by using a knife.
And here they are: deeeeeep!
One day before I put the wet sanding paper in a bucket with water and a bit of Meg's Last Touch.
So I went on with 2500 grit and the Megs backing pad. As lube I took Last Touch 1 : 4 water. Be sure to always use enough water! The surface must be really wet. Always move in straight lines and do not apply too mich pressure to the pad, let the paper do the work. After a few passes dry the surface so that you can see if you may already have removed to much of clearcoat!
When it's time to stop wetsanding, the surface dry looks like that:
Some people say you can't remove those sanding marks with a Dual Action Polisher, but that's wrong information. With my Megs G220, a Megs Cutting Pad and Menzerna IP 3.02, I achieved some good results after 2 passes of polishing.
Results:
Exatcly the way I excepted it to be. Scratches are still there but since the edges of the scratches are rounded and the light is now being broken expanded the human eye can't catch the scratch that easyly.
So it's still there but you can only see it by looking closely at it. As you may see, I was not able to catch the scratch with my camera.
Best regards,
Sebastian
Results:
Best regards,
Sebastian
