Results 1 to 5 of 5
Thread: polish pad vs. finishing pad
    Registered Member 2000's Avatar
    Mar 2004
    925
    19
    Question polish pad vs. finishing pad
    when ever I use a polishing pad on my truck (black) I get the tinyest swirls from #82. It seems I aways have to use a finishing pad to get the look pretty swirl free. this happens with both pc and rotery. any one run into this or have suggestions?
    2000
    2003 black gmc
    2500 HD
    52
    24,964
    514
    Re: polish pad vs. finishing pad
    Welcome to Meguiar's Online 2000,
    As Tim said, it could be your paint type, or another factor, such as pad speed, pressure, technique, etc.
    What do you use as a finish wax after the #82?
    Mike
    Mar 2004
    925
    19
    I use a speed of 1500 on a black and decker as that is as low as it goes....just got a dewalt to help slow down more but haven't the chance to use it. but again I get same results with a pc too. these are the kind of "swirls " only us knit pickers would see. I've tryed different presures with little or no change. I've used #26 and nxt to end but I'm curious to the reson why with the swirls before that step....I want to break any bad habits I have. If this could be related I've had a swirls free finish only to go over with machine glaze and had micro swirls reappear( finishing pad on machine glaze to.) I can get results I'm happy with, it just seems my method is compltly out of wack from everything I read on these forms and I do want to learn the "correct" why.....I would hate to ever be called a buffer jockey! thanks for all the help! these fourms are get tools!!!
    2000
    2003 black gmc
    2500 HD
    Mar 2004
    12
    I am thinking the problem could be that you are either 1) using a contaminated pad, or 2) picking up contamination from somewhere (like excess dust from a previous step, or even airborne dust). The reason I think this is that you said #3 with a finishing pad caused micro-marring. I use #3, and honestly I think the odds of it causing marring are about the same as if you used baby oil (maybe an exaggeration, but probably not by much).
    Here in Louisiana, I have a constant battle with airborne contaminants. Some I can see easily when it falls on my paint, but some I must look for it. What I do is when I bring my specific supplies for that session outside, I place what I am not using at that particular instant on my front seats. This keeps them out of the outside environment to prevent something landing on them. I also QD each panel as I work whatever process on it. This ensures I have a clean surface for polishing, waxing, etc...
    Another possibility is from the dried product around the spout of your bottle. I always notice this on my bottles, and do my best to wipe and poke at it till it's gone prior to putting the product on my pad. I have toothpicks in my detailing box just for this purpose.
    Just some ideas that may help you find a solution to your problem.
    Dave
    Mar 2004
    925
    19
    sorry I forgot to mention some things...yes I'm changing pads and those pads are only used with one product per pad. I'm in a garage which should help with air borne contaminets. and again a finish pad does the job fine but not a polishing pad. I have also tryed QD between steps, but I get this micro swrils before I move on to the next step. my black and decker machine woundn't allow me to go any slower than 1500, so I couldn't go any slower. I also should mention that I don't have this problem on any other of the vehicles I do (about 15 of them at different levels.) but this is the only black on.
    Thanks for taking the time to help.
    2000
    2003 black gmc
    2500 HD
  1. PC + #9 + Finishing pad 2.0
    By jmakado in forum The Dual Action Polisher
    Last Post: Sep 2nd, 2008, 08:03 AM
  2. Finishing Pad
    By 305Cummins in forum The Dual Action Polisher
    Last Post: Oct 24th, 2005, 07:22 AM
  3. #80 with a finishing pad
    By bluemoon in forum Detailing 101
    Last Post: Apr 30th, 2005, 09:13 AM
  4. PC Polishing with the Polish or the Finishing pad?
    By gb387 in forum Detailing 101
    Last Post: Dec 23rd, 2004, 10:43 AM
  5. #7 then NXT - Polishing pad or finishing pad for NXT?
    By Hellspawn in forum Detailing 101
    Last Post: Apr 15th, 2004, 05:01 AM
