Results 1 to 10 of 12
Thread: Lacquer paint checking question
    Aug 2008
    NY
    5
    I have a car with it's original acrylic lacquer that had been garage kept until last November. I am now starting to see checking on the horizontal surfaces. What exactly causes this? It isn't in direct sun often yet this happened. Is it the temperature changes? I wish I could smooth it out. The car has been waxed and well maintained prior to this.
    Registered Member SHYNEMAN123's Avatar
    Jun 2008
    DILLSBURG PA.
    56
    1,304
    779
    Re: Lacquer paint checking question
    What year and make is your car ?
    Aug 2008
    NY
    5
    This is on a 1987 Chevy Caprice coupe in white.
    56
    24,797
    517
    Moved out of Hot Topics and into Detailing 101
    Hot Topics are for typically questions that come up all the time and "we" deem worthy to be placed into the "Hot Topics" forum.
    All other questions should be posted to either Detailing 101 which is a catch-all forum for anything or one of the other sub-forums not in the Information Station.
    Thank you!
    Nov 2004
    SoCal
    2,280
    39
    Cool Re: Lacquer paint checking question
    Why do you think it’s lacquer? By ’87 pretty much all cars were painted with enamels.
    Anyway, there is no way to repair checking (a.k.a. cracking, crazing, splitting, alligatoring, crowsfeet). You have to live with it or re-paint.
    PC.
    56
    24,797
    517
    Quote Originally Posted by Shawn1283 View Post
    Doesn't sound right that GM was spraying acyclic lacquer in 1987
    Maybe I guess?
    Regardless there's nothing you can do to fix Lacquer Checking as it's a crack, or multiple cracks that are throughout the paint, not just on the paint.
    Thus is you try to abrade the paint in an effort to remove it all you do is remove paint and expose the cracks deeper and deeper into the paint until you hit primer.
    There's probably a number of reasons for lacquer cracking but one could be lack of flexibility in the paint so over time as it expands and shrinks with the panel that expands and shrinks when exposed to heat and cold temperatures the paint cracks.
    Besides the above it could also be a paint application problem that shows up as lacquer checking or cracking over time.
    Aug 2008
    NY
    5
    It's definitely lacquer, I compounded it not too long ago. It says so on the options tag in the trunk. I figured there wasn't anything I could do. :p
    56
    24,797
    517
    Wish we had an in-house paint guru, as in someone with a background in the chemistry of paints used in the automotive world.
    Wish... wish.... wish....
    Anything happen yet?
    Registered Member ClassicConcepts's Avatar
    May 2008
    Ridgecrest California
    46
    That's a nature of the beast with lacquer. As it ages, lacquer shrinks and cracks. Usually is is worse where it was applied heavier, some of the custom paint jobs years ago were really bad because the heavy application of clearcoats. What we did do that sometimes helped was to try a coat of a small amount of clear with a lot of thinner. Sometimes that would "melt" the old finish and blend it a bit, but it was a temporary fix. In some cases it would ruin the finish, but at that point we were looking at a total repaint anyway. Wish there was an easy fix, but there isn't.
    A good example of a lacquer finish with cracks is the 54 Chevy in my avatar. They aren't big, but I'll live with them till I do a repaint.
    too many cars, not enough time.....
    Jun 2008
    DILLSBURG PA.
    56
    1,304
    779
    Quote Originally Posted by mike phillips View Post
    doesn't sound right that gm was spraying acyclic lacquer in 1987
    maybe i guess?
    Regardless there's nothing you can do to fix lacquer checking as it's a crack, or multiple cracks that are throughout the paint, not just on the paint.
    it is poss. Might have been a fleet vehicle maybe even a police car of fed. Govt.
  1. Detailing 76 yr old Lacquer paint
    By Immaculate in forum Detailing 101
    Last Post: Feb 9th, 2009, 10:08 AM
  2. Detailing Lacquer Paint on 87 GM car
    By sd-slider in forum Detailing 101
    Last Post: Dec 1st, 2008, 03:49 AM
  3. How to remove 'checking' from lacquer
    By rphdiego in forum Detailing 101
    Last Post: Aug 4th, 2008, 11:05 PM
  4. What to use on original Lacquer Paint
    By JimmyS in forum Detailing 101
    Last Post: Nov 23rd, 2006, 06:21 AM
  5. G100 old lacquer paint
    By rsinor in forum Detailing 101
    Last Post: Oct 20th, 2006, 08:10 AM
