Anyone detailed (wash and wax only) a 40' motorhome?
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Anyone detailed (wash and wax only) a 40' motorhome?
    Des Moines, Iowa
    38
    5,605
    75
    I have a guy who wants me to wash and wax his 40' motor home. Its a CC/BC paint 3 shades of gray from light to nearly black. I would use NXT on it and depending on the paint some DC#1.
    I know its a lot of work but I have three weeks to do the job and I don't have to do it all in one day. I would use my pc to do most of the work. I guess it would take an entire day but can anyone fill me in on this?
    What might be a good rate? I know they charge $1 a foot to wash by hand then a wax fee on top of that, someone here told me about $160 for a wax, I know I would do a MUCH beter job than some others that I have seen. I have also heard a FULL detail can run up to $600. Again I know its alot of work but $250, that is what he offered me? I kind of figure a FULL 8 hours to do it.
    This is a photo of 2002 his is a 2001:
    Beaver Motorcoaches His is the "Patriot Thunder"
    Brandon
    2007 Black Chevy Avalanche
    My Albums: Avalanche
    Detailing BoZo jfelbab's Avatar
    Apr 2004
    Cape Coral, FL
    1,462
    29
    I believe Scottwax did one of these a while back. You might want to PM him and see what he charged. I also think he found the paint on some parts of the vehicle was very pliable.
    Registered Member Desertdawg's Avatar
    Aug 2004
    410
    18
    I have washed and waxed my RV's in the past. I now have a 30 foot fifth wheel with a super slide, and it takes me about 3 hours just to do a really good wash. (rubber roof included).
    The waxing (by hand) takes over 10 hours. Your results will vary, depending on the quality of the finish to start with.
    I don't do this professionally, so I really couldn't tell you what to charge. But please let us know how it goes for you.
    Registered Member Rick's Avatar
    Feb 2004
    510
    20
    While NXT would deffinitely last the longest your best bet for something that huge might be #66 Quick Detailer. It creates great results for a single stage process.
    Later,
    Ricky
    For great Meguiar's deals I use
    Auto Detailing Solutions
    Registered Member 2000's Avatar
    Mar 2004
    923
    24
    ricks right on with the cleaner wax. when I do my trailer, it's like one of those horror movies where the hall way keeps getting longer and longer.... something else, when you wash do a VERY good job on the rubber roof. if you don't the first rain will have all your work covered up by black streaks. even if it looks clean do it any way, you'll be amazed what comes off the roof. good luck
    2000
    2003 black gmc
    2500 HD
    Registered Member jchetty's Avatar
    Jun 2004
    92
    14
    please oh please tell me u plan on applying wax by pc
    366
    18
    Re: Anyone detailed (wash and wax only) a 40' motorhome?
    When it comes to washing and waxing a 40 ft motorhome you should figure about twenty hours in order to do the job right. It basically breaks down to the fact that you will probably be able to work at the rate of about two feet per hour. 40 feet = 20 hours. (For example; a 36 ft motor home would take about 18 hours and a 32 ft motorhome would take about 16 hours)
    The next thing you will need to do is to figure out what hourly rate you want (or need) to make. If you settle for $250 and it takes you 20 hours that'll work out to an hourly rate of only $12.50 per hr. At $600 for 20 hours of work you would be making $30 per hour.
    Your pricing should be based on the length of the motorhome. For example, if you charge $6.25 per ft the total cost would be $250. In order to make $600 for this job you would need to charge $15 per foot.
    If I were pricing that job here in Southern New Jersey, I would charge somewhere between $20 to $25 per ft, based on the age and condition of the motorhome. That works out to a total cost of between $800 and $1,000.
    Think about it. There is nothing worse than getting a detailing job that ends up taking much more time than you thought when you estimated the job. Remember, it is always better to under estimate and over deliver.
    FRANK CANNA
    Mirror Finish Detailing
    23rd Year 1986-2009
    Sep 2004
    43
    14
    gb387,
    Frank is right about the time it takes for the job. I am not an expert at detailing RVs but I've done 2 motorhome and 6 trailers since Aug and I charge $10.00 per foot and that's not very much for the amount of work involved (approx $20.00 per hr) but that's the ongoing rate in my area.
    Also don't forget that some area on the RV will have black streaks that will not come off with a normal wash and you probably will have to pre soak the RV with a good detergent before you wash and use a cutting compound in some stubborn areas before you wax. I hope you have a PC because it would be a hell of a job to do by hand.
    Good luck,
    Big Ben
    Big Ben
    Buff Tech Auto Detailing
    Key to success? Find out what your competitors hate to do and make it your specialty!!
    366
    18
    Hey Ben, it sounds like you've got a very good business going there. Keep up the good work!
    FRANK CANNA
    23rd Year 1986-2009
    I am the paint whisperer. Superior Shine's Avatar
    Feb 2004
    Covina / Los Angeles
    4,732
    205
    We charge $4 wash, $8 wash and wax, $12+ for wash, deep cleaning and wax,
  1. 40' Coachmen Pathfinder RV
    By snifferdog in forum Marine/RV Line - Product Discussion
    Last Post: Jun 16th, 2008, 03:24 PM
  2. motorhome detail
    By Stevens Detailing in forum Detailing for dollars
    Last Post: Dec 5th, 2006, 10:04 AM
  3. Motorhome revisited......
    By Elmer in forum The Dual Action Polisher
    Last Post: Oct 2nd, 2006, 09:50 AM
  4. motorhome
    By refurbish in forum Detailing for dollars
    Last Post: Jan 17th, 2006, 08:16 PM
  5. Waxing a Motorhome
    By Jim Wedlake in forum Discussion Forum Basics
    Last Post: Aug 1st, 2005, 06:42 AM
