Results 1 to 10 of 12
Thread: M105–rotary only??
    Jul 2008
    San Jose, CA
    4
    5
    M105–rotary only??
    I'm a newbie to the detailing world, but trying hard, and being patient over the last few months. I'm using a Cyclo along with M83 and M80. Both with pretty nice results. My question is regarding M105 as I've heard very good things about the product. I'm looking for something with more cut than the M83, but I've read here somewhere that the M105 is geared more to the rotary, which I'm not using–yet. I'd like to know what equivalent, or close to anyway, out of the pro line might be recommended, more fitting the dual action of the Cyclo for more serious correction.
    Addicted to Detailing thoryamaha919's Avatar
    Mar 2008
    268
    8
    Re: M105–rotary only??
    Well, with M105 it is for rotary use and hand application as well. Im assuming that what you are using is either a DA or an orbital im not sure. From what i understand when Megs released the M105 it was for those two application methods because when they test a product they want to have lot of good results before they say it can be used in a certain way. There have been some people that have used M105 with a DA and have had great results and others havent. If you really want to try M105 you can but, if your new to this then I would say do some reading and what are your goals? What are you trying to accomplish? Scratch removal, heavy oxidation, cleaning a daily driver? Let us know so we can help you?
    As always stated, "Begin with the least aggressive method and work your way up."
    Registered Member mike_svt's Avatar
    Jun 2004
    Burlington, VT
    237
    I've used M105 w/ my G110 3 times w/ great success. This is now my go-to product for cleaning and polishing (varies by pad type, pressure, etc). D151 is my product of choice for shinning up daily drivers. I have found that it has more cut than #83 and it leaves a nice finish (just as advertised).
    1999 Ford Contour SVT
    Silver Frost/Midnite Blue
    1966/2760
    Avatar Czar BlueZero's Avatar
    Aug 2006
    Green Bay, WI
    3,312
    42
    Here's a thread worth reading on the subject... M105 with a DA. Why not?
    Scott
    Jul 2008
    Houston
    163
    6
    Carlsson,
    I have heard some fantastic things about this great product, however I'd recommend doing some more research into what it does and how it performs to make sure it is what you need. From a financial standpoint, you are looking at 90$ a gallon!
    Here is a thread which Mike P and also Jason Rose contributed to that has really cleared up some things in my mind.
    http://meguiarsonline.com/forums/sho...ight=Ultra+Cut
    This is a VERY abrasive compound and should be used last and not first. As Megs always teaches, start with the least aggressive product and go from there. Keep in mind that this is not an all-in-one product! Jason makes that very clear in the linked post above. I quote him:
    Quote Originally Posted by Jason Rose View Post
    To be clear, please know that M105 is not intended to be a LSP. It is not a polish. It is not part of a one-liquid system.
    M105 Ultra-Cut Compound is...well, a compound. It is intended to go after sanding marks and severe defects. It is part of a two-liquid, two-step process...the second step being a Meguiar's polish that is positioned for follow up after a compound.
    Good luck!
    Jul 2008
    San Jose, CA
    4
    5
    Thanks for the replies all. It seems there are quite a few different opinions on this product and its usage. I've seen everything from "ready for LSP" after M105, to whoa, "much too aggressive", "rotary only", or "great with the PC", etc.
    That's the way it goes I suppose. There's never any miracle solution, of course.
    Is there a product in the line that can be recommended–more aggressive than M83, but more Cyclo "friendly"?
    Apr 2008
    Greensboro, NC
    1,378
    21
    I have read and have withnessed in person great results with a PC and M105 and M95, LSP ready I have not seen.
    Jul 2008
    Houston
    163
    6
    Well, to be honest, you should really listen to the source: Megs. I mean after all, they developed it and tested it.
    Good luck!
    70
    9
    Try D151 - Paint Reconditioning Cream
    52
    24,964
    514
    Quote Originally Posted by Carlsson View Post
    The Cyclo is unique in that it has two polishing heads instead of one, like this...
    Machine Photos - DA Polishers - Rotary Buffers - Traditional Orbital Buffers
    Cyclo Polisher
    At this time we don't do any testing of our products for this tool thus we don't have any official recommendations. The M105 is formulated for and intended for use with a rotary buffer or by hand.
    Many people have had great results using this product with a DA Polisher which is similar to a Porter Cable style DA Polisher but Meguiar's at this time does not have an official recommendation for using M105 with any type of DA Polisher so if you decide to try it it's with the understanding that we don't guarantee you'll get good results when M105 is used this way.
    Nutshell recommendation is you'll have to experiment for yourself...
