Results 1 to 10 of 13
Thread: Carpet / Upholstery using ShopVac?
    Registered Member RoyJ's Avatar
    May 2006
    26
    12
    Anyone do interior details with only a wet/dry vacuum and a garden sprayer?
    I've owned a Bissel consumer "carpet steamer" and was left far from impressed. The Rug Doctor is a much better performer, with its 2-stage motor and better built components. But it cost $35 to rent, or $700 to buy.
    So I'm thinking of a process as follows:
    1) Use the sprayer to wet the carpet with cleaner (my favourite is OxiClean
    2) Scrub with a brush
    3) Vacuum
    4) Rewet with plain hot water to rinse
    5) Final vac
    I've got a pretty powerful 6hp (I know the ratings are not REAL horsepower) vacuum, so it should make the extraction process pretty quick.
    What do you guys think? Anyone use a similar process?
    Registered Member christian6984's Avatar
    Apr 2007
    England
    31
    608
    18
    Re: Carpet / Upholstery using ShopVac?
    i have used the rug doctor on my seats (we can borrow it free from the supermarket i work for), i have never used a wet/dry vac, i think the process is fine, spray agitate, and extract.
    http://meguiarsonline.com/forums/showthread.php?t=22787
    Jan 2008
    I have a Numatic George that I use for cleaning my carpets and seats. I bought the full kit version that came with a smaller extraction head for use in cars and it works a treat. It came with a bottle of Dr Carpet as well as Numatics own fluid so I am using those for now but I am keen to try some APC with it. My method for cleaning is,
    1) Vacuum
    2) Spray with fluid (using the pressure squirt from George) and work in with the extraction head. No reason why you can't spray the fluid and work with a brush instead.
    3) Extract
    4) Repeat 2 & 3 if needed
    It brings the seats and carpets up like new and the wet extraction gets all the sand type grit out of the carpet that normal vacuuming can struggle to lift. I don't go back over my work with water and have no problem with the cleaned surfaces attracting stains or excess dirt.
    Registered Member Raymond4646's Avatar
    Jun 2005
    41
    67
    Quote Originally Posted by RoyJ View Post
    3) Vacuum
    5) Final vac
    Yes, it works well. I used an extractor nozzel after agitaing the carpet with a brush and cleaner/water. Then lightly wet and extract till cleaner is removed. Just dont over saturate the are. Also, make sure to check with the owners manual, as some wet/dry vac direct you to remove the filter before heavy water usage.
    Registered Member SHYNEMAN123's Avatar
    Jun 2008
    DILLSBURG PA.
    56
    1,304
    779
    I have only ever used a shop vac for carpet and seats and door panels.
    1 vac throughly
    2 pretreat stains with your choice water based gp cleaner
    3 small bucket 1/3 full hot water
    4 light spray small area with gp cleaner
    5 dip scrub brush in hot water shake off excess and scrub area
    6 shop vac throughly
    7 dry with clean light colored towel, the towel will do 2 key things 1 dry area and 2 pull dirt from carpet or fabric.
    8 repeat process until towel stays clean after wipe
    when you use to much liquid, water or cleaner th dirt is trapped and after it dries it returns to the surface.
    Jun 2008
    DILLSBURG PA.
    56
    1,304
    779
    Almost forgot, change water in bucket it will get very dirty quickly.
    Registered Member audionutmike's Avatar
    Jul 2008
    Gilbert, AZ
    166
    15
    Up until the last couple of months I've only ever used a shopvac. But then I got the Little green Machine from Wal-Mart. The thing is great. $85.
    check out some of the posts from either KerrinJeff or audionutmike (me) to see what I'm talking about.
    Hope this helps
    The power of the flex compells you!!!
    Registered Member chessplayer's Avatar
    Sep 2006
    258
    14
    i have used the wet/dry vac b4 ...with some nice results...remmeber to not over wet ....brushing will help lift stains definetly.....i too use a wet/moist rag to remove dirt plus it helps on the drying .......oh yeah and with 5hp and up you should be fine.....
    Sep 2005
    14,243
    535
    I also use the shop vac as my extractor.
    Registered Member acsuppa's Avatar
    Nov 2004
    518
    19
    Quote Originally Posted by J. A. Michaels View Post
    Same here. I never needed to do a "complete" interior upholstery cleaning(luckily). Only spot cleaning and my Rigid shop Vac works great. I would like to get a Bissil LGM. Royj, if you plan on doing a lot of interiors, try to save up the money to buy a good quality cleaner. Just like any tool, you'll appreciate it every time you use it.
  1. Quik Out vs. Detailer Line Carpet and Upholstery cleaner
    By Tuck91 in forum Consumer Line - Product Discussion
    Last Post: Jan 15th, 2009, 07:47 AM
  2. RED WINE taken out by carpet and upholstery cleaner
    By onawrxhigh in forum Professional Line - Product Reviews
    Last Post: Mar 19th, 2008, 05:58 AM
  3. Problem with HD Carpet & Upholstery Cleaner...
    By LocoGT in forum Customer Service Hotline
    Last Post: Feb 28th, 2008, 11:08 PM
  4. Discontinued Carpet/Upholstery Cleaner - G9416
    By CARSGroup in forum Consumer Line - Product Discussion
    Last Post: Jan 23rd, 2007, 02:52 PM
  5. Detailer's Carpet/Upholstery cleaner...HOME?
    By gollums_friend in forum Detailing 101
    Last Post: Jul 13th, 2006, 07:42 PM
