Results 1 to 8 of 8
Thread: How can I remove spray paint from car paint
    Jul 2008
    Lugoff, South Carolina
    Some how I've gotten some white spray paint on my black 2007 Toyota
    Camry. Its very find but if you look close you can see the tiny tiny white
    spects. Question? can I get the stuff off the paint?
    Jerry
    Registered Member SHYNEMAN123's Avatar
    Jun 2008
    DILLSBURG PA.
    56
    1,304
    779
    Re: How can I remove spray paint from car paint
    Is There Any Chance It Is Road Paint And Not Over Spray ?
    Jul 2008
    CA
    5
    try claying it
    Sep 2005
    14,243
    535
    I would give claying a try. Or you could try a small test spot with body solvent. Just remember to wash and wax when finished.
    Apr 2008
    Jakarta Indonesia
    114
    12
    The least aggressive step would be claying, if you couldn't remove it try compound. if that also doesn't remove the over sprayed, you could use wet sand grit 2500/3000. I believe this last step is your last option.
    Learning True Art of Detailing TimG's Avatar
    Apr 2008
    Borneo - Mount Kinabalu
    1,802
    46
    Do a test spot. Try claying at 1st. If claying even with aggressive clay (red) then bodysolvent (other similar products).
    Tim
    Registered Member TxZ71's Avatar
    May 2008
    Sweetwater Texas
    22
    Claying will get it off. I would suggest sooner than later. I got red overspray on my truck and clayed different panels over several weeks. It seemed that the panels that I did last were much harder to get the paint off of than the first ones I did. But claying will work. You may need to use some good pressure for some of the spots. At least I did.
    Jul 2008
    Macomb, Michigan
    3
    Only use the following suggestion if its a factory finish. First, take you finger nail and see if the specks will pop off. If they do then you know the overspray hasn't bitten into the finish. If the finger nail method doesn't work then use Enamel Reducer from an automotive paint store but be sure to check a small spot like under a rocker panel. Go over the paint lightly and quickly to get the overspray off this is the method I used when working in a bodyshop and detailing shop. We just didn't have time to use the clay. But don't forget to test a spot first and don't rub hard on the spots. Try this method before using the clay, it may save you time.
  1. how do i remove frozen ice from the paint on my car?
    By sidekicklxondeck in forum Detailing 101
    Last Post: Dec 23rd, 2008, 07:33 PM
  2. New car paint paint sealant and scratches
    By TomRaz in forum Detailing 101
    Last Post: Apr 29th, 2007, 07:40 PM
  3. Replies: 4
    Last Post: Feb 5th, 2007, 08:38 AM
  4. Replies: 6
    Last Post: Sep 11th, 2005, 06:37 PM
  5. How to remove road paint from car?
    By RDVT4ME in forum Detailing 101
    Last Post: Oct 16th, 2004, 09:58 PM
