Back plate for DA use as a sander?
Results 1 to 7 of 7
Thread: Back plate for DA use as a sander?
    Avatar Czar BlueZero's Avatar
    Aug 2006
    Green Bay, WI
    3,313
    47
    I'm thinking I'm going to try to use my G100 to finish up a few spots on my hard wood floor before I stain. Any suggestions as to a backing plate to use? I don't really have time to order one online so if I could get it local that would be great. Can I just use the same one I use for detailing? I'm thinking that I would want something with a bit of foam on it for cushion but maybe not.
    Or if this is just a dumb idea all together I'll buy a belt sander.
    Scott
    Person PorscheGuy997's Avatar
    Apr 2006
    Southern Indiana
    1,345
    33
    Re: Back plate for DA use as a sander?
    The 7336 that I have came with a flat backing plate that uses stick on sanding disks.
    I'm almost positive I saw a plate similar to the one that came with the PC at Lowe's in the power tool section. It was a Gatorgrit brand of sorts that came in a few sizes.
    Either way, the PC works great for sanding projects.
    Chris
    Dasher Detailing Services
    Aug 2006
    Green Bay, WI
    3,313
    47
    Thanks Chris! We don't have a Lowes but maybe I'll run to Home Depot and look tonight.
    I've been trying to use my little 5" palm sander but I need something with a bit more bite for a few spots.
    Scott
    57
    24,779
    517
    You've probably already read this thread...
    Refinishing an old desk?
    Don't know if I would ever tackle a floor using a DA Polisher...
    Before
    It's on end in this picture but I think it's standing about 7' tall.
    Here's a close up of a stained area from something that was leaking out of a jug?
    After
    Taped-off and sanded with 220 using my G100 (Took all the work out of it). There were some pretty bad stains in one area that I couldn't sand all the way out...
    2-Coats of MINWAX Red Mahogany 225
    Aug 2006
    Green Bay, WI
    3,313
    47
    Hey thanks Mike! That thread is new to me.
    I'm not doing the whole floor, just touch ups. I rented a floor sander and did it all with 36 grit and finished with 80 grit. The floor sander couldn't get the corners. Also there are a few spots where I didn't work out the 36 grit marks so I want to finish those down before staining. This has turned into a much bigger job than I ever thought it would be. I could post the photos and do a write up now that I will have used the G100. lol
    Scott
    Aug 2006
    Green Bay, WI
    3,313
    47
    I gave it a try last night with the backing plate I have (think it's the W67DA). It didn't seem to work the best, it was a bit hard to control since I couldn't keep it perfectly flat on the floor. I went to the power tool store at lunch today and picked up a 5" Porter Cable adhesive backing plate and 50 pack of paper. It seems to have a bit more give than the backing plate I was using. It was the same backing plate that was on the PC they had on display. I'll give that a go tonight and see what happens.
    I also checked Harbor Freight and they have a belt sander for about $5 more than the backing plate I bought. lol Hmmmm
    Scott
    Reforming paint abuser RogueGypsy's Avatar
    Mar 2008
    The Great NorthWet
    279
    PC makes a hook and loop backing plate as well as the PSA backing plate. Any PC dealer should carry them although you may have better luck at an actual lumber yard or tool store rather than a home improvement center.
    FYI: Beware of cheap belt sanders. Belt sanders remove a lot of material VERY fast. The cheap belt sanders don't usually have a flat sole plate which means by the time you smooth the area your working on, you've sanded a groove in another area. Then you end up chasing a groove around the floor as your leveling the previous groove. It's entertaining to watch, but no fun at all to participate in.
    Have fun!
    Life isn't about 'weathering the storm', it's about learning to dance in the rain.
  1. sander/polisher
    By prelude86 in forum Detailing 101
    Last Post: Jan 23rd, 2008, 06:04 AM
  2. what size back plate does megs reccomend
    By steveo3002 in forum Customer Service Hotline
    Last Post: Sep 21st, 2006, 03:28 AM
  3. G100 back plate ?
    By socalhonda in forum The Dual Action Polisher
    Last Post: Jun 17th, 2006, 11:56 PM
  4. Using G100A as a sander
    By Pete-FWA in forum The Dual Action Polisher
    Last Post: Oct 21st, 2005, 04:52 AM
  5. Help! How do I install the back-up plate?
    By FlaresideLariat in forum Detailing 101
    Last Post: May 14th, 2004, 09:50 PM
